IF I WAS YOU I'D GO WITH THE FIRST OPTION( WASTE OF TIME) IF THE OUT COME OF SHIMMING IT UP WAS ALMOST AS GOOD EVERY ONE WOULD DO THAT INSTEAD AND IT IS PROBABLY ONLY A LITTLE GIT CHEAPER IN THE LONG RUN, AT THE END OF THE DAY ITS IS STILL A VISCOUS AND IS NOT DESIGHNED TO DO WAT YOU ASK OF IT,
IF YOU GO TO WWW.GARAGE-13.COM THEY HAVE SOME PRETTY GOOD PRICES ON NEW AND USED 1.5 AND 2 WAY DIFF CENTRES AND YOU WILL BE LEFT WITH SOME CHANGE FROM $1000 ALL THE SECOND HAND DIFFS ARE STRIPED AND CHECKED OUT BY PROS SO IT IS PROBABLY THE BEST OPTION.
HOPE THIS INFO WILL HELP.
Hey i'm thinking about shimming my standard viscous lsd. I'd like to hear from ppl who've done it.
I've heard everything from its a waste of time, to it almost makes it like a locker.
Opinions?
sorry if my reply does'nt related to your questions.i'm quite new about all this thing.
i ve installed a standard viscous lsd to my ceffy..probably same with u.My problem is when taking a corner at a lower speed ,there is some strange noise i heard from the rear axle....it normal ?
Strange noise would be associated with something being wrong or the diff not being a V-LSD. Ie, a mechanical 1, 1.5 or 2 way would make clunking noises around corners.
More related to this thread, I spoke to 2 diff places who said they would be happy to shim the diff, although they called it something else I can't remember now, but said it would probably blow up in about 6 months and I shouldn't waste my time. Also said it's nowhere near as good as a mechanical one.
GTRs come with a mechanical diff as opposed the the viscous in the GTST. We use a shimmed standard diff in the race car and it is nice and tight.....we've too tight for a street car but you can get them looser :cheers:
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
