Hey was looking at upgrading the radiator on my r32. i want to get a koyo 53mm aluminium one. They only make them for GTR's, does anyone know if these will fit to a gtst? will they just bolt up or lot of modiification...
i have no clue so would appreciate any info thanks
https://www.sau.com.au/forums/topic/71209-gtr-radiator-to-gtst/
Hey Roy, didn't you have issues with underbonnet temps at one stage? How did you sort them out?
Yeh water temps of 320 deg Cand 820deg C under bonnet temps can easily be fixed with a $19 fire extinguisher...cheaper then one of those fancy radiators...meh what a waste of money:rolleyes:
thanks ppls ill have to have a look
im hopin to start a group buy and get em cheaaaaaaap ronin
is 53mm to big for street use
as in is there anything wrong with getting too cool
becuase i notice on some nights (early morninish) my water temps are only just over 70degrees
All silly talk a side. Grab a tape measure. I think you will have troubel fittign such a thick radiator in the std position because of the power steering. Typically a 40mm seems to be an easier and equally effective fix ....and then there is always the $19 fire extinguisher:)
i will find out marcus. i think its bigger than that. But im not sure.
Its just hell bigger than the good ole 1987 Jap Spec one which is about as thick as a "toast-cut" piece of bread
Thanks mate, I spoke to him and he said that the 40mm is a bolt in solution with existing fan and shroud (for a 32 anyway) and the 57mm requires electric thermos and removal of shroud... didn't mention anything abour p/s pump...
I think Ben runs a 40mm in his 33R, so if it works for him in his 500kW beast a 40mm should be ok for my low power jobbie :D
raz0r$harP - I tihnk there is a group buy for PWR already - check FS group buy section :)
Ash - is yours a 40mm race radiators jobbie? I have to invest after my 3-laps-to-overheat at Sandown a couple of weeks ago :D
yea ive seen it bu the koyo ones are bigger and polished ant not too much more thats why i was asking
i want a twin core alu that way will never have to upgrade and hopefully shouldnt ever have any problems........ cough
The 40mm PWR is twin core and polish is cheap.:D
