My RB25DET has an adjustable FPR on it and a walbro fuel pump. I've noticed a loss of power throughout the rev range lately. I checked all the sensors, checked base timing, put brand new iridiums in it, and I'm running splitfire coilpacks. I checked the fuel pressure at idle with and without vacuum and they seem ok.
Sometimes while I'm watching the fuel pressure gauge I'll see it dip a few PSI slowly but surely and occasionally I have to readjust the FPR to compensate. I've done a few of these adjustments in the last few days. Basically what I'm wondering is if my fuel pump is on it's way out?
-Matt
https://www.sau.com.au/forums/topic/71228-fuel-pressure-questions/
i recall seeing a few threads covering the walbro pressure levels and how much they pump. on skyline wiring it only gets 12volts, and its pressure levels and pump per/hour levels etc are based on 15volts (such as in supra im pretty sure). do a search on walbro 15volts and you should find it, may be causing your problem
Get rid of the walbro.
They are a lard of junk once you push on them. Ok if you running it as a lifter pump for a surge tank, with a big bosch after that... then you wont notice the problem like i will be doing.
I was far from happy with my walbro, so it was more cost efffective to do a surge tank/bosch/walbro as a lifter setup than throw away some $$$
As for an FPR, you shouldnt really be using one anyway. There is no need
