Checking the battery is the obvious one.
When you push start it, it generally does take a while for the RPM to go back to normal so thats not unusual. It you had problems with the coil packs it wouldnt prevent it from starting it would just cause it to misfire.
Other things to look at are:
-Starter motor
-Alternator
Just look at all the things that could prevent it from starting but not affect the car once it starts running. But I would be lead to believe that it could just be the battery.
Cheers,
Have you got an alarm with an immobiliser fitted? Depending on how the immobiliser is wired can affect if / how the car will start.
Then again, a bit more info on how it won't start eg starter doesn't work, engine spins but won't fire, etc would be a really useful guide for a well-considered diagnosis of the problem.
  • 1 month later...
hey mine wont start either? it was running perfectly fine...the battery seems to be connected properly and there seems to be power in the car because the head unit is working the tt is functioning.
But when i turn the key it makes some funny noise like a high pitch sound as if it was coming from the alarm/immobiliser. does anyone know what this could be?
i tried it again and it started! i fiddled around with the connections a bit and noticed there was heaps of acid build up on the terminal. but yeah i did forget that the mechanic said to replace the battery as there was a crack :O so i'll be getting my new battery tomorrow!!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
