Hey guys, When i press the break on my car my driving lights, tail lights and dash lights come on..
If it helps, when the key is in the ignition, and i hit the breaks it makes a beep sound as if the lights are on (because they are) even without the car started.
If you had this problem, or know someone who has, please let me know how you fixed it.
Thanks in advance..
Dayne :wassup:
https://www.sau.com.au/forums/topic/71285-electrical-problems/
Sounds like you have a really bad earth. Somewhere in your electricals when you put the brakes on the power is finding another path back through to other car parts. This would mean that your brake lights will also be dimmer than usual.
To fix it? Try looking at your fuses first? Then look at where your loom, lights, etc... are earthed to the car. This is the most common cause, where the lights aren't earth correctly and therefore earth via other bits.
Found the problem,
dissconected my light i replaced, and it was fixed... looks like there is a difference between the harrneses, might of been out of a series 1 or something.. or series 2 insted of the 1.5
Changed it. and its fixed!!
thanks 4 the tips guys, made me realise + fix the problem
Dayne
Uh guys, wen its un plugged the problem is fixed, and when all the lights are in bar one the problems fixed, yet when the harness is full of lights the problem is there again?? any ideas on whats next...?
Thanks again. Ps. When i break the lights do come on brighter, so its not as if its not safe or anything its just damn annoying!
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
