buy a fluorecent lamp cover, then cut it to size... that's what a lot of guys in japan do for their "clear" ceffy indicators. Then get some Jaycar clear LED lamp replacements which light up orange and you'll have fullsick clear indicators. For like under 10 bucks :D
https://www.sau.com.au/forums/topic/71286-ceffy-indicators/#findComment-1315268
what side do you need i think i have a spare one around.
when looking at the car from the front, its the one on the left. Although i'm pretty sure that they would work on either side. Don't think i will be getting a RWC for awhile yet as wanna get other things done b4 compliance first, so not in huge rush. If you are willing to sell it PIMP_DAT, if you find it, PM me a price..
Cheers
Ben
https://www.sau.com.au/forums/topic/71286-ceffy-indicators/#findComment-1321019
I think I've got spare also both cos I installed my own on my kit.
PM if it doesn't work out.
[edit: as far as I understand it it has to be orange when it's operational so if you have a clear cover but orange bulb when it's on it will be orange so no problem]
https://www.sau.com.au/forums/topic/71286-ceffy-indicators/#findComment-1321078
or if you're still worried about not passing the testing rego thingy i forget what it's called,
take the bits you cut out of the flourescant bulb cover,
then take it down to a paint shop and tell them to mix a few drops of orange with thinners, to make orange tint if you will...
then spray the inside of the flouro bulb covers, or if you wanna save a buck or a hundred, make the orange tint yourself!
just thought of that then, pretty good huh?
https://www.sau.com.au/forums/topic/71286-ceffy-indicators/#findComment-1321776
