Hey just trying to get the Air/fuel ratio close on my car so i can drive it to the tuner (4 hours drive :D )
I understand the Apexi turbo timers is just an estimate but is there a way to get it close enough so i can drive my car to get it tuned, trailering it is out of the option too!
How do you set up the O2 voltage my car at idle reads 1020v (on the power FC) theres no 1020v setting on the APexi TT!!!!!
Can anyone help me out???
Thanks
Luke
https://www.sau.com.au/forums/topic/71307-apexi-pen-turbo-timer-af-tune/
the 02 reads between 0.00mv and 0.10mv or 1.00mv. I think you are referring the airflow meter value? AF in the sensor display is airflow meter and it will be around 1.00volts at idle (its max value is 5.00volts). The pen timer needs to have its wire tapped into the cars ecu loom (02 wire which is oxygen sensor not airflow meter). once that is doen you can with handbrake pulled up move to a/f o/2 on the timer press right and then it will show theoritical value then press left, move up to a/f, press right and it will show a/f and then flash to oxygen sensor value and then back again. once its working when you move the timer to display a/f instead of it showing --- and light changing from green/red constantly it will show like 18.5 or higher at idle and "green" for lean and then when you drive it should hover around 13.0 ish and god mixed between orange and red for rich. if you still have --- no matter what make sure when you move the timer to display oxygen (the 2nd item of the four) it has a value and the value is changing all the time, thats the oxygen sensor value. if its 0 or --- then its not wired in correctly or the 02 sensor is dead. they die after about 50,000 k ish
I understand its unaccurate, but i thought i could at least get it close! That doesnt help me out though!!!
Anyone got any ideas on how to get a close read out??? as 4 hours is along way to drive when the cars either rich or lean! i dont wanna damage it on the way there!
Ok i understand now.
You have upgraded the injectors.
Therfore the standard ecu won't run it (it will overfuel by a mile)
However, in the powerFC, there is an option which will trim the entire base map to suit larger injectors, without changing every parameter. (Have to do a search, im not familiar with the powerfc, to find what setting you have to change)
If you don't change this, it will overfuel with the bigger injectors, the same as what will happen with the stock ecu.
Do you have the Turbo Timer wired up to the O2 sensor at all?
If it is wired up it will give the feedback from the standard "Narrow Band" O2 sensor.
However i wouldn't use this sensor to tune, its highly innacurate at anything but stoich ratio's.
Yep the stock computer runs very rich, very very rich as the injectors are upgraded!
yeah i have changed the whole map in the Power FC so that it is close, but all i did was change the injector flow down untill it stoped belching black smoke out the exhaust!
On the power FC i had to bump the injector flow down to 44% (base map is 100%) as it was overfueling!
The timer is wired up to the 02 sensor (exhaust sensor) im getting a readout but it says like 12.8 and then i read that you can alter the setting of the O2 read out, something-arother about depending on the voltage of the o2 senser!
If i have the car running rich (like as close as i can tell, by bumping the whole flow up and down) would it be fine to drive???? can any harm happen from running the car rich?
My cars been out of action for 5 months now, so as you can imagine im itching to get it tuned and back on the road...My R31 just doesnt cut it :rofl:
If you have the maps trimmed down so they are close, what you will find is under light load driving (i.e off boost) it will be running in closed loop operation and maintaining a stoich ratio of 14.7:1 and your plugs won't foul.
(Closed loop is where the ecu uses the feedback from the 02 sensor to trim the injector pulse to keep a stoich ratio, minimising emissions and maximising economy)
So if you drive under that condition, it should be fine.
If it were a brand new motor just rebuilt, i would advise against running it rich as the rings won't bed properly and this needs to happen in the first few hundred km's of driving.
If the motor has just had bolt ons applied, i wouldn't worry to much.
Just drive it offboost so it can run in closed loop and your plugs wont foul.
If you boost it and the plugs foul, you may not get the car there without removing and cleaning them.
Not a job you really want to do on the side of the road.
Running it a little rich is safer than having it lean out; I suppose, at the worst, you'll just foul your 'plugs up a bit and lose a bit of power on the run there. The former is easily fixed, and the latter is basically redundant as you're getting it tuned anyway.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
