Hi all,
On Sunday 24 April at 1pm, there will be a special edition of the channel 10's Trackside featuring the Full Lock Drift Nationals! Please have a look (or tape it if you are going to be at the drags), it wont dissappoint.
Please support this sport, have a look, and give channel 10 a call to ask for more - even if you arent into drifting yourself, get behind this motorsport for your fellow SAU members that are :D.
This will be a huge help in getting the sport of drift off the ground, and the only way media coverage will continue.
Cheers
Steve
PS, sorry for the late notice
https://www.sau.com.au/forums/topic/71310-drift-on-tv-please-read/
Sweet action! On a "mainstream" channel and coverage was a lot better than the last drift event on sbs i think it was.
Thought it wouldnt be as exciting to watch as jap drifting, now im thinking about taking the trip over east to watch the next semi's :rofl:
Wasnt a bad coverage - please guys, ring channel 10 and ask for more so we can have MORE :rofl:
Her32, I was at the Sydney round last year, and it was well worth going. The local guys arent bad at all, but the jap D1 demo, words just cannot describe the crazy speeds and how close these guys drive - video just doesnt do its justice
Oh, and the sbs coverage of the malalla event should be better than the last one. They are doing the full pro series thing and will have similar commercial type coverage - so I am told.
Keep an eye out for it on May 1, 12 non, SBS
(EDIT: more coverage = more sponsor $$$ = more drift comps australia wide. The Drift Australia round is talking of coming to WA in 2006, would be nice if we had a decent following/local series going before then )
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
    • nice work, welcome to the world of CAD! fabricating accurately in 3 dimensional space is beyond me....I almost always end up making something more than once...sorry I mean I extensively use prototyping
