Hi everyone,
Im so happy the other day when my supplier had a look at my new car for the first time. The sleeper is a total beast.
It looked to be a slightly modified car but when he popped the hood he found a massive top mount turbo that wasnt even on the engineers report!!
With all the mods we could expect 500bhp , we assume there must be bigger injectors and hopefully the internals are done.
Didnt expect this much power and now its gonna be a lot of work to bring it back to stock to get complied.
here are some of the mods i can see,
Apex intercooler with piping
hks pod with cold air induction
a garret top mount turbo of some kind
apex power fc and some other meter on dash (maybe air/fuel?)
full exhaust
aftermarket manifold
bigger injectors and maybe forgies
quickshifter
firm clutch of some kind
tien adjust suspension
black advan wheels
blitz boost controller
bov
and so much more...cant wait to see what else there is when it arrives!!! :wassup:
The car seems professionally modified with the best gear, with all the mods i expect it to push in the high 200s kw at the rears :aroused:
Anyone driven or know of an R33 GTST with this sort of power? it was suppose to be my new daily driver LOL
11sec runs shouldnt be a prob right?
Anyone know what it would be worth around?you wouldnt beleive the price i bought it for.
Cant wait to get it and hopefully i can get it ready for adelaides next auto saloon.
https://www.sau.com.au/forums/topic/71312-my-new-r33-gtst-import-a-500hp-beast/
pics!
i know of a certain white gtst, other sau memebrs here would know also, around adelaide that im sure is putting out this amount of power either close to it if not more, equiped with aftermarket forgies, pistons apparently istalled or supplied by jun. It also was an import.
Matt's R33 has 299rwkw, I think Clints is about the same, and Joels's R32 will certainly exceed that when finally tuned, David's R33 has around 260rwkw, etc etc. There are plenty of others around too. The trouble you will have is traction. I think Matt with 299rwkw has only done a 12.2x run so far, as he can't get the power down. Sounds like a beast - nice buy! Sorry to tell you though, you will be looking at an easy $2,000 to stock it out for Regency then get your goodies put back on :D The prices for any performance workshop to even touch your car will blow your mind.
Yes, there are handful of skylines, gtst, with big horsepowers. Im sure the distinct white gtst im refferring to puts out more than 300rwks'. btw, aint clints and joels both rb30's?
In regards to regency, nightcrawlers on the money when he's referring to getting your car actually on the road. It can be a long and frustrating journey if heavily modified which seems to be the case indicated by the mods you listed. But than again each import is inspected differently.
yes i bought it so cheap you couldnt even import a stock auto at that price, i have calculated the cost to take mods off then put it back on. Mine is also white, its a total stock looker on the outside.
I already bought R34 GTR wheels for it and full GTR kit. If i have cash ill do a pearl gold, pink or some other funky colour paint job over it. Hopefully it will arrive on the 11th may but people will see a lot of this car in the city, ill definately make it stand out since there are too many skylines around. heres a couple of pics, oh anyone by anychance have any idea what turbo it could be(i know its hard to c)? Supplier said its a garret though...
Clints is a rb25 with 26 internals. It is very nice and already pushing ~340rwkw.
Darrens (Bl4ck32's) and mine are rb30det's.
I will be pushing upwards of 300rwkw and darrens should be some where around the 350rkw mark.
Definitely some hipowered GTST's getting around, or soon to be getting around. :)
Mine with the stock RB20DET turbo on 9psi made 175rwkw with a small peak to 176rwkw, I consider it to be 175rwkw.
It makes this at ~4400rpm and is held flat until ~4900rpm where power drops of dramatically due to the small crappy turbo. :)
I found it interestering how and where it made power,quite happy with the results.
The problem is it feels a little like a turbo diesel the way power is made then drops off. :)
Prolly seen a fair bit of action, but maybe a rebuild down the track and you will have one hell of a car.
I'd say you got a good deal but I don't know what you paid for it?
Keep us updated on the car, I'm keen to know how it turns out and exactly what the car comes with.
car was about 5k, im expecting to do a rebuild hence the price i bought it for but cant plan what iam exactly going to do as i havent seen the car myself yet.
Definitely some hipowered GTST's getting around, or soon to be getting around. :P
It makes this at ~4400rpm and is held flat until ~4900rpm where power drops of dramatically due to the small crappy turbo. :D
WOW, 350kw atw is crazy....only about 630bhp!!! more power than a V8 supercar LOL
My R32 gts with a RB30DET is making 290 RWKW using stock bottom end and stock cams.
Traction is definately a problem with even slightly worn tyres, brand new tyres improve the grip heaps.
Joel,- What turbo is clint using on his RB25 to make 340 rwkw, how much boost??
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
