Any other Skyliens running?  How does the mph compare to the std turbo times?
I was the only Skyline running against a mob of LS1's. Heathcote in May should be interesting if we can get a group to go up as it will be same day, same track.
WIth the stock turbo, the best i managed at Heathcote was a 13.09@105 with a 2.09 60'.
Tyres are Sumituno's HRZ 11, 255/40/17, wouldnt mind trying RE55 or the new Toyo's. Will have the burn these ones up first though
12s!
Congrats on running 12s - its a good feeling - my previous 2 cars did and it feels goodd!
Im aiming to get my series II 33 running stock turbo into the 12s,its got an ARC front mount,jap Rom and a few other goodies, i rekon It can do it easy. Ive had quite a bit of practise at the strip. Ive seen guys with modded 33s ie. turbo etc that cant pull low 13s even!! You have to know how to launch the car and how to set it up for the race, ie. warming tyres, tyre pressure etc.
Nice times Robo. :(
How were the LS1's holding up?
Hard question, they ranged from blown to turbocharged, some serious cars there and alot running quick times. Still i beat a lot. If i had some decent tyres and more attraction, i would certainly show a few more up.
They'd be the tyres you've got under it then? :(:)
My standard turbo 33 gtst went 12.7 @ 108mph late last year with numerous 12.9's and 12.8's in trying to get there.
Adrian
Nice times Robo. :(
it was a shit weekend, a few decent LS1's there.
A fair portion nothing wonderful. For the LS1 nats i was dissapointed to see a turnout which in would call average
Robo's... i say your car, but there wasnt anyone near it the times i went past it.
I was there with Rossco and his purple 32 GTR.
Only did a 11.02 :) so sad.
Poof diff broke just after half track and just missed the 10 lol.
Lets do a Skyline Nats or some sort of skyline drag event. Would be nice to run some other skylines but since ive owned it (2 years) theres never been one organised. Hopefully the one next month (Datsan, Nissan) event might attract a few.
Last dyno session we picked up another 8rwkw with some extra boost which bought it to 225rwkw at 5700rpm. Now this is on a Dynomite dyno which the owner from experience running back to back against a dyno dynamics dyno reads 6.7% less. So putting this back into the calculation, it should be around 240rwkw on a dyno dynamics dyno. Boost at the moment is just over 19psi.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
