yeap.. we'll all meet up at stanwell tops after the run :P not sure which way we'll go back.. either nasho or freeway.. i suspect the group will want to split up at that point!!!
also all, there is a VERY VERY VERY dangerous 25km/h corner... its after the completion of the nasho.. just when you think you can speed up.. please watch all the cornering speed signs, as that particular corner is very deceptive and i've known a few people to lose it there!!
  • Replies 412
That describes the whole nasho run. respect it or it will cost you lots of money! :flamed:
i remember organising one of these aggggggges ago on SAU
and what was at the stanwell tops lookout? two cops in a 4wd. came up to me and said whoever organised this meet - you boys better get going or i'll start defecting the lot of you. what a bummer it was.
Before i got my line i used to take my Citroen down the nasho, one night i got pulled up after we were just chillng at the lookout (bald hill) and coppers came up and tried to dick everyone for everything. They have to come from Helensburg so it takes about 5 mins for them to get there if some local calls. The fact that it is satruday night should be OK, but im not promising anything, there is always a risk of coppers whenever there is a cruise. i wouldnt be supprised if a cop has already read this and knows about it.......... :P
:P  i wish it was sat already!  did the old pac last night... such a russsshhhh!!!!  i want more :D
u hoon!!
anyways james is not coming, he forgot that he had something else organised for sat night!!
ill am most probably still in!
Ok guys!!!  new cruise!!!! :P
Destination: Nasho Run
Time: 8:30 at P6d homebush
Meet 2: 9:30 at waratah st, kirrawee... we should leave by 10 for the nasho run...
Date: Saturday 14th May
Attendees:
Sl!m
Craved
Ben101
Wilch
Black R33 Gtst + R33
Rukus
Matboy
SiksII
James
x]SPHYNX[x
sproosy
z3n2k
Mr_G
henzie
Mr R32 M-Spec + R34 Gtt
HCR32
Liz
aaronrb25t
Maybes:
ed R34
Aplex
Silver Gts-t
TommO
Bizzrevhead
OK seriously since when am i a mayby?? comone monie... keep up to date.
well in that case.... im comming... getting all excited bout it.
If everyone reads the signs about cornering speed and doubles it, everyone should be fine (with some exceptions) ive done the nash before and if ur just cautious everything is ok....
Just if u see a wombat or soemtrhing crossing the road, dont swerve for it, just go streight over teh top. it will save u and probally the person behind you.
should be a good turn out. hopefully the cops wont do what they did on the last cruise and tell us all the piss off..... assholes.
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
