GTR - MAP or MAF better?
Will be looking at fitting an after market ECU in the near future to my GTR.
I've heard that the 6 throttle body setup of the GTR makes it difficult to tune with a MAP sensor.
Thoughts or recommendations?
Gav,
It all depends on the amount of power you want out of the car. MAP sensors are better for high horsepower, but will give you reduced resolution for your A/F mixture. MAF's are good if you have Z32's but even they will run out of resolution on a high horsepower engine.
I run a MAP, but that's because I didn't want the restriction to the airflow, but you can still get 900hp cars running on MAF's. If your buying engine managment then get one that has the option of MAP sensor, but allows for the use of other MAF's.
The six throttle bodies make it more difficult to tune whether you have MAP or MAF, but this is only really a problem on high horsepower cars, which will often use a large single throttle body, not something I'd worry about until you hit 400rwhp.
See'ya:burnout:
Thanks for the comments
Probably belongs in another thread, but the reason I was asking is that I am considering using one of the new Wolf 3D P&P ECUs for my GTR.
From the specs that I have read, this can only use the internal MAP sensor that comes with the unit. The Wolf, however, seems like pretty good value and should have all the functionality that I need.
I am very familiar with the PFC from my previous S15 and got some good gains by fitting an RB25 AFM on the SR20 motor.
I would have no problems with using a PFC and 2 x Z32 AFMs on the GTR, however I really would like air intake temp. correction for Perth's hot summer days!
By the time you get the PFC, Commander, 2 x AFMs and Data-Logit (if you want to log runs/ load alternative maps) you are just about into Motec territory for cost!
Hi Gav,
I am in Perth and have the Wolf 3D Ver4 P'n'P in my car, I run the map sensor but am sure that you can leave the factory AFM in if you want, don't know if it supports the Z32's though. You can still have the temperature compensation even without the AFM.
I heard from Steve at SST, who fitted my Wolf, that the new P'n'P for the GTR may contain 4WD control functionality, do you know if this is true?
Good luck with making a decision, it's not an easy one to make.
See'ya:burnout:
P.S. I am very happy with my Wolf.
Almost certainly will get Steve to do the Wolf install for me.
Glad to hear that you are happy with the work you had done.
Can't imagine how the ECU would control 4WD functionality as it would need to interact with the ATESSA computer. Still, will let you know what is possible when I get this done in a few weeks.
Cheers
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
