For sale: Turbo off R33 $200 -will trade for lwo/high mount exhaust manifold for RB25
I have a series 1 turbo taken from my r33 RB25DET skyline. The car has done 150,000kms and from what i can tell the turbo is origional.
PLEASE NOTE: The compressor wheel is not made from the plastic/nylon gear the compressor wheel is made from steel and only looks black in the pics due to a shitty cammera and dirt build up. The model number on the turbo is 45V3.
The car blows absolutly NO SMOKE. The turbo has minimal shaft play approx 1-1.5mm back and forward. The turbo does not come with bend pipe, water lines, oil lines and is missing the actuator.
The turbo was taken off by B&R Motorsport up here in Brisbane, for upgrade to GT30, and i was told that they broke the actuator when the pulled it off.
This turbo makes an awsome upgrade for the RB20DET as it bolts straight on. The actuator from the RB20DET turbo will also fit on to this turbo.
I am looking for $200 + Postage OR a clean swap for an Exhaust Manifold either Low mount or High mount, preferably Low, either new or used that is in good condition that will fit the RB25DET factory turbo and RB25DET Head.
Brisbane and sorrounding area buyers can also have a look at the turbo before purchase if that helps.
Sorry about the pics they are taken by cammera fone and there as good as it gets.
Thanks for looking.
Greg.
P.s. I allready have a factory low mount manifold, i'm after a stainless steel one. Thanks for the offers anyway.
  • 2 months later...
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
