Looking to purchase a powerFC for an RB25/30 using an R33 n/a head. questions:
1) must i specify that i want it to drive an N/A head (injectors etc are different capacity obviously) so that it will plug straight in?
2) i understand i can select different AFM's easily enabling me to upgrade to a Z32 or Q45 AFM, however can i use a MAP sensor if chasing really big power? can the outputs of a different meter be calibrated so that the powerFC can use them?
3) does the powerFC come with tuning software for a laptop (i know it has a hand controller) so that i can tune it, or do i have to search for a dyno tuner who has licenses for the software?
cheers
https://www.sau.com.au/forums/topic/71334-powerfc-sensor-calibration/
The standard PFC uses AFM, Djetro versions can use MAP.
As for needing MAP for "really big power", I have seen an RB make 1100 bhp using AFM's, is that "really big" enough "power" for you?
The NA injectors are 270 cc's (from memory) so you can adjust the PFC master fuel correction to -20%, that will get it running. You should tune the maps though for long term use. But 270 bhp is not much for an RB30/25, so I suspect it is only a tempory situation.
You can get Datalogit for lap top tuning, although the Commander does a pretty good job.
www.fc-datalogit.com
:D
fantastic, cheers. i'll ditch the 3 bar map sensor i have at the moment.
what do you do about largish (500 engine horsepower) power AFM's? i have heard rumours of people using Z32 AFM guts in a 3 inch pipe to slow the charge velocities down and not max the AFM out...... how would you go about this? using two AFM's on separate induction pipes is not possible as the AFM must be placed after the intercooler in my application. i understand a Q45 AFM goes up to 300-odd rwkw but they're expensive buggers and hard to find.
p.s. when this engine is up and running, i want you to tune it. do i have to book?
edit: will be running with GTR 440cc squirters.
Use a Q45 afm. They are available, just look in the for sale section. They are capable of more than 300 rwkw ive read on here somewhere (i should be up around 350 with mine).
They cost like in the region of $300...not that much more than a z32 afm.
Like SK said use Datalogit, or you can buy the Power fc sofware from Nengun.com these days i believe....
Bl4cK32 answered most of this.
I will add that I have seen a car in Japan with a Q45 AFM plumbed into the pipework from the intercooler to the plenum. Certainly no problem maxing out a set of 444 cc injectors. My own RB31DET maxes out 565 cc injectors with a single Q45 AFM, and it is placed before the turbo (ie; in the usual location).
Sorry we only work on team race cars, there is simply not enough time to do retail work during racing season. Plus you wouldn't want me to tune your car, I am far from the best tuner. Shoot I don't even do the race cars, our team tuner won't let me near them. But he is a genius after all.
:rofl:
okay, so he's the man i need. i really want someone with experience with powerFC's but most of all experience with RB30DET's. i'm buggered if i will let any joe schmoe tune this engine once it's done, i want someone who knows their way around it assways.
sounds like the Q45 AFM is the go, it's ID is even larger than the 3 inch pipe i'll be running if those figures are correct. do they handle pressurised air fine, just like any other hotwire AFM?
The Skyline is saw the boost through Q45 on, had ~85 mm ID pipe to match the AFM ID (from the intercooler to the plenum). I have never tried it myself, so I have no idea what issues they had getting it to work. I also don't know what boost they were running, it had a big ass HKS turbo on it, so it had plenty of airflow.
:rofl:
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
