Yep, as the thread title suggests, I f#cked my clutch.
The day started off pretty good with some low 14's and high 13's.
Then I managed to pull a 13.7, my new best!!:D
But then, due to peer presure I entered the burnout comp to show the front wheel drive panzies how its done. My car was smokin up but it wasn't my tyres.;)
I made it about 50 metres up rockingham road before my car just stopped.
My old man just tow'd me home in his jag.
I ain't too pleased, but I got my 13.74!!
https://www.sau.com.au/forums/topic/7134-137-and-a-fcked-clutch/
  • Replies 99
Hicks,
I'm sure I've told you before that jap cars aren't designed to do burnouts, leave that to the V8 boys, there cars are only good for burnouts.
I am sorry that you stuffed your clutch but it shouldn't be too expensive to fix, I think you can get the factory one fixed for about $250 at the Clutch Factory.
If your after a stronger clutch, as this will likely happen again with the new power, then I can get you a twin-plate or heavy duty clutch pretty cheap.
The old clutch burnout would have really impressed the V8 guys, they were probably having a good chuckle at your expense.
Consider this an expensive lesson in how to treat your car. I guess I won't be racing you on Wednesday night then!
See'ya:burnout:
Well that's the right attitude, normally people blow 2 or 3 factory clutches before making the decision to move, which I'm sure Macka will have to do soon aswell. I'll ring my mate on Monday, I know he has a Nismo 5-puck at the moment, which might be enough for your car, but I'll find out which twins he has and the price.
I'd suggest you sell that flash stereo you bought and go for a decent clutch, your bound to have more fun with that.
See'ya:burnout:
Yeah I did the same thing to mine, without the burnout of course, and it definately does stink. I was joking about selling the stereo.
A factory one repaired would let you limp around for a bit longer, but you wouldn't want to race the car too hard. It depends on whether you can get the funds, maybe an early Christmas present from the folks?
See'ya:burnout:
I doubt it.
It was ****ed today before the burnout, the burnout just put it out of its mysery. If I didn't do it, I doubt it would of lasted the drive home.
Oh well, Shit happens.:whackit: (im aware this has nothing to do with anything, but its f#ckin funny!)
$830 or there abouts depending on your exhaust setup for Ross @ Perth Autoclutch to put in a 2500pound pressure plate and 9 finger clutch plate. If you want to see pics of it, find rev210's post about his ogura flywheel as he put the same clutch in as well with his new flywheel. Works great, no slip, just a bit stiffer to drive.
Rob
Autoclutch is the place to go for a new clutch mate.
I have the 9 button ceramic clutch and I kept my old stock pressure plate.
The take up is lovely for a button clutch, I've never seen anything like it! As usual (for button clutches) the clutch friction point is closer to the floor but it feels as soft as the stocker without the slippage.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
