  • Replies 64
We've been discussing this in another thread so I'll recap some of the discussion.
There are so many octane boosters to choose from that the choice is difficult to make. The best octance booster are Nulon Pro Strength Octance Booster, NF Octane Booster Racing Formula and Toluene.
The first two you can buy from the shop the later from hardware stores and servo stations. These octane boosters will raise PULP by about +2.5RON. The octane rating is related to when the engine will begin detonating and pinging, it is not a reflection on additional power. With a higher octance rating though you can advance the timing and therefore get more power.
There are a number of boosters that provide little in the way of improved RON (+0.2RON) but will add more horsepower, these contain nitromethane. Some examples of this are PowerFuel Super Street Nitro Based, PowerFuel MaxRace Nitro Based.
Hope that helps.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105006
Higher RON will protect your engine from detonation, a big plus. The amount of power from these boosters is relatively minimal, so I would go for the protection, allows you to run higher boost safely. If you want the best of both worlds then use VP Motorsport fuel, 107 octane plus shitloads more power.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105096
MRE,
All octane boosters will cause deposits on your spark plugs, they will tend to go an orangey color. I said it had the highest octane rating, which I was presuming was for the drags, I wouldn't recommend using octane booster all the time.
I would use it but only on the occasions when you know you're going to be running high boost and leaning on the car alot.
See'ya
:burnout:
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105143
Ait,
I wouldn't bother using it in normal street driving, just wasting you money, I bet if you take your plugs out they'll look like shit. Seriously if your using BP Ultimate (98RON) then I wouldn't bother, just add it if you go racing or drag racing. The higher boost will need the additional octane to ensure no detonation.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105150
I'd definately agree with not using commercial octane booster....the crap fouls up your plugs. It has been suggested although, you keep a bottle in the boot for those times you can't get 98ron fuel (of course only the good quality stuff..if you got it in Coles or Woolies, then I reckon it would be crap...like their oils).
Toluene on the other hand can be bought from petroleum companies, I think in 20 litre drums, and mixed with your petrol (ask advice on the proportion per tank)....but care must be taken as it is a CARCINOGEN.....(causes cancer....very dangerous stuff). The best advice, I think though if you're not drag racing is just use one of the commercially available 98ron fuels (BP Ultimate, Shell Optimax or Mobil Synergy 8000 (only available in NSW/SA & Vic I think))....if you read their Material Data sheets, they are pretty well on par with each other...although I prefer the BP (don't know why...just seems to go better).
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105339
This from an old thread (Backyard Race Fuel) initiated by rev210 on 27/8
Toluene = Methyl-Benzene.
A search of the net uncovered that it is not on the NIOSH carcinogen list, but it adversely affects the central nervous system.
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105364
It's definately not a carcinogen. It is dangerous tho. Don't go sniffing it on purpose. You will die on a high.
BTW ordinary fuel IS carcinogenic, linked to leukemia.:D
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105410
Originally posted by GTS-t VSPEC
Either way, I would advise that you use gloves when mixing it. No point getting sick from it, then you can't drive your car!
See'ya:burnout:
It's pretty good at cleaning oily grime your hands if you forget to wear gloves:D The central neverous system effects occur if sniff it. Thats why harware stores have it locked up sometimes (to prevent those who do this from stealing it)
Mind you ordinary petrol is far worse to spill on your hands but most people change fuel filters and stuff without gloves. Maybe they should wear some.
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105413
I promise to make this my last on the subject, but the US ATSDR (agency for toxic substances and diseases registry) website states........
'How likely is toluene to cause cancer?
Studies in humans and animals generally indicate that toluene does not cause cancer.
The EPA has determined that the carcinogenicity of toluene can not be classified. '
The above statement doesn't sound too convincing to me....I definately wouldn't clean my hands with it !!!
:eek:
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105440
ARhhh...now I've got a bottle of STP to get rid off. I think I'll keep it for those times when I won't have Premium around.
Thanks guys, think I'll stop using these things. For drag racing days, I'll use only Nulon Pro. Supposed to be one of the best besides toulene.
If 98 ron is good enough, how much power loss is there since our cars are supposed to run on 100 ron?
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105570
:eek:
The mineral safety data sheet (australian version) does not classify toluene as a carcinogen, nor does any other world standard for toxicity. As I said before however, ALL general use petrol contains carcinogenic substances. And the vapours from petrol contain these very same carcinogenic substances. Like to fill your car up in a chemical protection suit now? If you don't then you aren't reacting consistantly with the belief that toluene might be carcinogenic.
I find that the same people that label toluene a carcinogen are blissfully unaware that petrol is recognised world wide as a carcinogen. They probably even wash parts (and hands) in it and siphon petrol using their mouth?:D
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105585
Toluene.....you'r supposed to put it in your tank....not clean your teeth with it!!
You can get it at Autobarn 20L drum $48 it's a heap better than any of the retail octane boosters being pure Methyl Benzine. Now the hot weather is here I add 5L to my tank when I go to the drags or racetrack as a hedge against detonation.I think this gives an octane rating of 99.8. incidently none of the BP servos I enquired at could supply it .
https://www.sau.com.au/forums/topic/7137-octane-booster/#findComment-105869
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
