Sniffy,
Yeah, just keep a bottle handy for the occasions when you can't get to a decent servo.
51Jay,
Thanks for the details on the location and price, what is your suggested mixing ratio, I've heard between 15-30%.
Giz01,
Couldn't they find a decent car to perform the test on?? Just kidding. I think it is sensible when racing to add it just for added protection.
Ait,
Your the one who has been running your car on 98+booster, notice any difference? Just means that we don't advance out timing as much as we would with 100RON fuels.
Everyone,
I don't like to get covered in any chemicals, whether cancer causing or not, just be sensible and don't sniff or drink it.
See'ya
:burnout:
  • Replies 64
If the octane rating of Toluene is really 122 then adding
10% gives 100.4
15% gives 101.6
30% gives 105.2
I've decided to keep the tuning for BP 98 octane and add 10%
when racing on full boost as a hedge against detonation
51Jay,
Don't want to burst the buble but at 20% mix the RON improvement is +2.5 and 30% is the maximum recommended, therefore +3.7RON is the best your likely to get. This is taken from an article in a magazine and tested on a knock engine. This is still more than enough to protect you from detonation, therefore it is still worth doing.
See'ya:burnout:
Doesn't work like that I'm afraid, life would be so much easier if it did. The fact is you can't work it out. The only way to determine the RON(research octane number) is through the help of a $200,000 knock engine, which all oil companies use for testing of there fuel's RON.
Don't believe all of the bottles claims about there octane boosting ability either, the set there own scales which don't reflect well to real life. If you want guaranteed high octane then use an unleaded race fuel such as Elf or VP Motorsport Fuel 103, about 107RON, the highest you'll ever need to run in any normal car. With the higher octane you can advance timing and get more power also.
See'ya:burnout:
Originally posted by GTS-t VSPEC
51jay,
Toluene is good stuff, if you don't mid premixing it, just remember not to drink the stuff, some of the other guys use it as mouth wash. Go figure!:bahaha:
See'ya:burnout:
thats cause we are tough, and have cast iron guts from drinking to much coke
Premium unleaded's like the BP Ultimate, Optimax etc. are supposed to provide better fuel economy due the increased fluid density. I don't know why an octane booster would improve the fuel economy, but if it does that's great. Not likely to offset the cost though at $20 per 60L.
See'ya:burnout:
Originally posted by 51jay
How do you work it out ??   I'm using 98 octane for the BP Ultimate and 122 for the Toluene which are the figures they claim and just multiplying and dividing the appropiate numbers
Roughly,
The BP ultimate 98 stuff would be a closer guestimate due to it having the lowest % content of aromatics.
The mixture of 30% toluene to 70% BP98 will yeild an approximate RON of 105.
Well the tune up + Toluene must have done something. Just back from Willowbank. My previous best 14.8 dropped it to 14.3 good enough to cream 3 x commydoors including a HSV Club Sport 5.0LV8.......Skylines 3...commydoors 0 :)
14.3 @95, 14.6 @ 99.7 ?? 14.8 @ 91
Was very hot, Track temp 42' Iwas leaving after 4 runs at 6.15 pm when a few other Skylines were just arriving. In retrospect I should have stayed on and run acouple more when everything had cooled down a bit.
MRE Still behind you in the mph, just couldn't make the 100.
I'm really looking forward to Wed night though, should be pay off night
GTS-T V Spec :) and especially Club Sports that do huuuuuge burnouts :)
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
