For sale is my Hawk EC21 EMS. head on over to EFI hardware to check out full specs. basically it is a complete management system like microtech, autronic, motec etc but much cheaper because it's australian made.
it tunes in 125rpm increments and has a higher resolution tuning map than any other ECU out there (perhaps bar megasquirt) for very fine adjustments. it does closed loop for good fuel economy also.
i will include with the package:
- Control unit
- Full loom to suit Z18T 4 cylinder which even comes with the three critical relays so you can just wire up about 10 wires into your existing loom and it will run.
- Water temp sensor, ECU is calibrated to this. you can calibrate your standard sensor if you so choose.
- Air temp sensor, calibrated also
- 3 bar (30psi) map sensor for big boost applications
- Delco TPS which you may or may not use, you can calibrate your standard TPS to work fine if you desire
- ECU-computer comm cable
- CD with wiring diagrams, software and a full manual which describes every detail about the functions of the ECU
- A number of base maps which you can choose from, depending on your application. EFI hardware will be happy to email you a base map if your engine isn't in the list.
the reason for sale is i have chosen to go powerFC which will plug straight into my loom.
looking for offers over $700 for everything. this is a very easy to use and fine tuning resolution ECU, i would definately recommend it to anyone wanting a cheap ECU upgrade.
pm me or reply here, i'm happy to post it but you pay ($15 or so anywhere) and i am located in brisbane
https://www.sau.com.au/forums/topic/71397-fs-stand-alone-management-system/
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
