For sale is my Hawk EC21 EMS. head on over to EFI hardware to check out full specs. basically it is a complete management system like microtech, autronic, motec etc but much cheaper because it's australian made.
it tunes in 125rpm increments and has a higher resolution tuning map than any other ECU out there (perhaps bar megasquirt) for very fine adjustments. it does closed loop for good fuel economy also.
i will include with the package:
- Control unit
- Full loom to suit Z18T 4 cylinder which even comes with the three critical relays so you can just wire up about 10 wires into your existing loom and it will run.
- Water temp sensor, ECU is calibrated to this. you can calibrate your standard sensor if you so choose.
- Air temp sensor, calibrated also
- 3 bar (30psi) map sensor for big boost applications
- Delco TPS which you may or may not use, you can calibrate your standard TPS to work fine if you desire
- ECU-computer comm cable
- CD with wiring diagrams, software and a full manual which describes every detail about the functions of the ECU
- A number of base maps which you can choose from, depending on your application. EFI hardware will be happy to email you a base map if your engine isn't in the list.
the reason for sale is i have chosen to go powerFC which will plug straight into my loom.
looking for offers over $700 for everything. this is a very easy to use and fine tuning resolution ECU, i would definately recommend it to anyone wanting a cheap ECU upgrade.
pm me or reply here, i'm happy to post it but you pay ($15 or so anywhere) and i am located in brisbane
https://www.sau.com.au/forums/topic/71397-fs-stand-alone-management-system/
