i was tightning them with 1 hand until it was firm and then pop.....
i thought the valve or whatever it was called was going down but no, the bolt broke....
anyone have a spare bolt for the cam brackets?
or will nissan charge me like $94.86 for 14 of them i dont need?
yeah, thats similar to the thing i got from bunnings the other day.. havent used it yet...
either way, i am f**ked...
i have to either drill and re-thread the hole and use a bigger bolt, or try using an easy out....
but the main question is
Does anyone have a spare cam bracket bolt i can purchase off them, or a part number for nissan... (or will they only sell me a pack of more than 1?)
yeah, but if i drill it out, wont there still be some of the old bolt left in there?
and also, i could damage some of the tread the bolt would attach it self to....
atleast if i use a easy out tool, i just have to drill a small hole into the broken bolt, then easy it out....
its about 1.5cm into the head, so might be a little tricky
If your going to replace the cam journal/cap, whatever they are called...be sure that it is toleranced for your engine. I ran into troubles when i used one of another engine on my otherwise perfect RB20.
I wouldnt think its overkill to drop off to a mechanic to be sure that the tolerances are all ok...as from the factory the gallery for the camshafts is line bored/honed (whatever the proper term:)) so sure its a bugger and agro, but best be sure:)
i snapped it replacing the cams... not from driving it...
want to do it all myself as a learning experience...
And whilst i didnt snap the stud, it diud seize in the cap which meant that i needed to source another one. I used a 2nd hand one off another RB20 that appeared to be in perfect nic, but as i said the tolerance turned out to be a bit different...so when car was off at tuners, the inlet cam became hard to turn and just about seized meaning that the cam belt skipped teeth and i ended up with bent valves:(
Im all for trying to do yourself, just be sure about the journal size should you decide to replace it
Its common for the bolts to seize in the cap , the alloy corrodes ( white stuff ) and its hard to pull the bolt out .
If you notice all the cam caps are mumbered and you must put them back whre they came from otherwise you are looking for trouble . If you must use a new one you have to torque it down then tunnel bore to suit , of course you can use a second hand one and measure the clearence but you must make sure its within specs .
Warpzor ,
the best way to get the broken bolt out is : drill as big a whole as you can without going into the thread , so about 4-5 mm will be about right . Get an easyout and you should be able to get it out . If you drill a very small hole you will snap the easyout . Make sure you drill straight .
If you stuff the thread , drill a bigger hole and put a helicoil in there .
Whatever you do dont break the easyout in there so dont force it to much and dont use a chinese aeasyout !
Good luck with it
Depending on how the bolt is snapped off, you might also be able to weld something (like a nut) onto whatever is left of the broken fastener.
If you don't really know what you are doing, it might be worthwhile getting one of the mobile thread repair type guys to come and extract the busted bolt. For $100 or so it might save a lot of time, frustration and could prevent further damage. Removing busted easy outs isn't much fun.
did the same thing on thursday last week tourqed all inlet up to 9Nm last one just spun in the head them pop thought it was the wrench clicking off but nope!! snaped in the head
stay away from ezy outs there nothing but trouble
here is what i did
a friend of mine made a jig used the cap as a guide made a dowell like object that sliped tightly into the cap taped it through the cap and slightly into the head the jig had a 3mm hole in the dead center
once clamed with the cam cap in place with the other bolt drilled really slowly using inox to cool and lube the bit, thi step is done to drill the dead center of the hole other wise there is a chance that the bit will slip and you wont get center, because the bolt is hardened steel and the head alloy, alloy is much softer and the drill bit will prefer this
once the 3mm hole is drilled get a hold of a
M6 x 1.0mm
hellicoil kit hire one if you have to itll save you alot of money,
follow the steps drill out rest of hole with the drill bit attached
then using the thread tapper cut a new thread all ensuring that you are going straight
cut all the way to the bottom of the hole
the slowly screw the helicoil into the new thread
make sure you clean out the hole before you place bolt back in
(another tip is, if you have 1 get a magnet hold it on the smaller drill bit and use the drill bit as a magnet and get all the fillings out, also use masking tape and tape over the area so no fillings get in the head)
as for bolts use any hardened or high tensile bolt got mine from repco they are M6 x 1.0 35mm witha hardness rating of 8.8 these are common bolts they are the goldy collour ones spoke to an engineer they said thay are fine because of the tension they are at
the reason i went this way is that once you have ezyouted the old bolt the thread is ****ed even if repaired has been weekened from the abuse it just coped
helicoils are stronger than the original alloy, but i just like to be safe
sorry this is such a long wined post but its something that i feel strongly bout
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
