Hi guys
Ive hooked up my electronic oil temp gauge, but im not getting any realistic reading.
Now I need to know this -> at the present moment the gauge is floating. Not connected to anything, so the reading im getting is pretty haywire (150 deg). Once its mounted (its getting screwed into the oil cooler remote relocater), and is grounded, will it work?
I tried to ground the temp sensor, but the reading didnt change.
Is there a way of testing either the gauge or the sensor to see if either of them are faulty ?
Thanks heaps for anyone who can help :(
https://www.sau.com.au/forums/topic/71438-electronic-oil-temp-gauge-problem/
Sounds like it probably needs to be earthed. Simplest way to check it would be to rig up a power supply and appropriate earth system then dunk the sensor in a pot of boiling water.....if the gauge reads anything other than 100C (more or less), there's something wrong.
Well
The gauge is powered correctly (accessory, constant batt, ground and illumination)
The other end goes to the sensor. But the reading isnt correct.
I havent connected the sensor to anything yet, b ut just having the sensor in the air, I get a reading of like 160/170 degrees which is off the scale and is j ust plain wrong?
I hope the gauge/sensor isnt stuffed.
Does anyone know how the sensor works and what reading it sends to the gauge?
There are two wires going to the sensor. Im assuming one must be a voltage source, the other must be the signal running from the temp sensor.
At the same time, the sensor MUST be grounded, or is it ?
Cheers
Hmmm ive just tested it with a multimeter.
The sensor works, in that it gives off a change in resistance according to a change in temperature.
Is it possible that the unit has been decalibrated ?
Theres those plugholes on the back and when you take them off, theres variable resistors ? Any ideas ?
Im lost :)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
