Takakaira is only a well known shop in Australia. Takakaira Japan does not have a showroom nor do they stock any parts in their office. You can call them in Japan and they'll tell you the same thing.
Theres plenty of places to buy brand new stuff at retail which is still cheaper than Australia. The big retail store there is Super Autobacs and theres a few around Tokyo. Theres quite a few other places as well.
https://www.sau.com.au/forums/topic/7144-japan-in-3-days/#findComment-105115
one s15 power fc, one apexi gt intercooler kit, one apexi avcr and five cougars thanks.
maybe email nengun and ask him where to go?
he has the connections over there.
one of my friends just came back from japan about 2 months ago, he knew someone over there who introduced him to all the signal guys and stuff, he went for a ride in their drag gtr and stuff plus he went to the trust, hks, apexi factories and stuff.
phwoaaaaaar :D
https://www.sau.com.au/forums/topic/7144-japan-in-3-days/#findComment-105158
Originally posted by cereal_jacques
Land of the Rinsing Sun?? :bahaha: :bahaha: :bahaha:
Loz is gonna come back with Japan's latest rice. He'll be years ahead in neon, sticker & LED technology........
LOLZ, u beat me to it ya bum! :P almost word for word LOLZ:shake:
https://www.sau.com.au/forums/topic/7144-japan-in-3-days/#findComment-105812
hahaha friday night wangan drives are "fun" hehehe *smirk* *smirk*
land of the rinsing sun huh? u sure u'r goin to japan n not like thailand or sumfin?
Well while u'r there buy a sh!tload of stuff off yahoo.co.jp n post it to u'rself in australia!
https://www.sau.com.au/forums/topic/7144-japan-in-3-days/#findComment-106025
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
    • Tapin,    So got mine up and realize a few things. First was my slave line doesn’t reach the other side, so I have to get a longer hose made. I want to ask did you have to extend your wires for the CD009 sensors? One on the driver side(right side of car looking at the car from the rear) and one on the passenger side( the left side of car from rear). And do you know what those two sensors are respectively? I know it’s not Speedo since we talked on this already. And I may have to separate the trans again to swap out throw out bearing. We will see. Did you run your RB slave cylinder? I know you cracked your original but replaced it with a nismo. But wasn’t sure if you bought the one designed for the CD009 or not. Thanks
