I put in a 6" speaker with a mdf adaptor i made up to bolt into the original shitty nissan holes. I basically took an outline of the factory plastic adaptor and then cut it out in mdf... then cut a whole right in the middle to mount the speaker. only used about 15mm mdf aswell, and it all clears the window and door skin.
JK
