Hi
Can someone enlighten me to the laws now governing basic modifications in nsw? I'm looking to do the following mods:
full exhaust
coilover suspension
pod filters
....pretty basic stuff i thought, but apparently i need an engineer's certificate.
Does anyone know what i'm legally required to do? Who can provide me with an engineer's certificate and at what cost?
thanks
http://www.rta.nsw.gov.au/registration/dow...s/vsi/vsi15.pdf
List of RTA approved engineering signatories in NSW. The scheme is currently being replaced (with the Vehicle Compliance Certification Scheme), but at the moment the list is still current.
Look to get an engineering certificate for around $450, depending on what needs to be done. Costs will vary, but that's a price I got quoted when I asked around.
You can't get pods engineered for.
Need stock airbox i was told.
Incorrect. All that is needed to get a pod engineered is a drive-by noise test. The test basically involves:
1. Driving up to a marker in 3rd gear @ 50km/h.
2. When you hit the marker, accellerate for 20m, then back off.
3. Repeate 3 or so times for an accurate reading.
The engineer is at road level, about 3m from the edge of the road, reading the noise your car makes with a db meter. Anything under 90db is good, and a certificate will be issued.
Costs about $500 to get a whole car engineered.
Yeah you can get pod engineered. Apperantly the only ADR this relates to is noise so as long as it's under 90db you're ok. Mine is un-oiled and the engineer stupilated this on the certificate however I'm not sure if that's a requirement. I didn't have to do a drive by test.
In terms of exhaust it has to be under 90db mine was read from approx 30cm at 3000rpm.
The coilovers - as long as the height is 100mm from the ground you're ok, this applies everything but the tyre and wheel.
And off course - the whole lot you get engineered has to be deemed safe engineering wise, so things like coilovers that are 101mm off the ground don't cut it if they're sticky-taped on :)
Also - technically, you DO need an engineers with all that stuff however you're not going to really get picked on (atleast around where I live). If you're planning on getting any other mods in the near future consider getting them and then having the whole lot engineered as it will end up cheaper.
As for the actual laws - a good guide is checkout the RTA website and look at all the motoring requirements they put out. A car in NSW is (from my limited knowledge) subject to those guidelines and the national ADRs. I was having a chat to my engineer and he says even for him it's hard to go and look through the whole lot because the laws and guidelines are all over the place.
Another myth he busted for me is the shift pattern on the gear knob, apperantly one of his customers he'd engineered got defected for it. When he heard back from the customer he went through ADRs and regulations to look for it, and it's never mentioned anywhere so he said that's rubbish too.
PM me if you're North Shore area and you need a good engineer. The guy I used was an absolute champ and he quoted me the best quote, when he came out he ended up charging me less anyway.
What's required seems to differ from engineer to engineer from talking to them. When I wanted to get my pod done, one told me it was ok, another told me it would be fine so long as it had a serial number on it (??). Anyway in the process of looking for one too, as I think the money outlaid would be better than fines for a defect - plus I'm sure it would make my insurance company happier if all the mods are registered with the RTA..
Thanks for the info guys.
My insurance company is also saying that it needs approval of the mods by the RTA as well....??? Doesn't the engineer's certificate take care of this or is there an inspection that the RTA will perform as well?
I'm fairly new to nsw so I don't know all the laws.
The POD filter will need to be enclosed in some type of box (CAI)
A H pattern is required near the gear stick that indicates the shift pattern.
Cheers
I've got both engineered fine. Did someone knock you back or have you just heard this?
Anyway - tk80, when you get the engineers certificate, they give you 2 copies, one for the RTA, one for you. When you get your rego you have to take your cert to the RTA and they will keep one copy for their records.
When they print you your rego sticker it will have a code on it stating your rego conditions - these will relate to those things specified on your engineers cert. Your copy you must keep in your car as RTA/police can ask you for it and it's a condition of rego.
If you're anywhere near North Shore/Chatswood area or within a reasonable area of that give me a PM and I'll give you the contact details of my engineer. He was recommended to me and I now recommend him ;)
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
