  • Replies 44
Rip the N/A RB20 out and use it as ship ankor. Replace it with an RB20DET/RB25DET and mod that or sell the car and buy a turbo skyline. be realistic.
Dont mean to be too negative but N/A performance is 2 costly for what you could get out of forced induction for half the cost. Probably less.
out of an RB20DE!? There may be some ppl out there that can get that sort of power out of N/A but u'd have to really know what your doing...just seems like a huge amount of work compared to the forced induction route, that's all.
The point i was trying to make is- to me it seemed like we wanted to go fast (200 rwkw) thats why i suggested forced induction if he's on a budget. I wasn't rubishing N/A.
But if this guy really wants N/A than go 4 it i suppose...
Haha, mine comes out of a 4.5ltr engine. Not arguing yes its easier to just turbo an engine, but there is nothing like the feeling or driveability of an NA engine, and quite simple some people just prefer them. I have a personally prefer NA, and some forms of supercharged engines, with low to mid range response, im not a huge fan of turbos.
I've seen 140rwkw VL RB30 with a medioka cam and it made 198rwkw with a 75hp shot of nos. I've always wondered about the rb30 26 head conversion two cams higher compression say 10.5ish maybe higher, tuned length individual throttle bodies topped off with trumpets. I would say 200rwkw wouldn't be all that far off maybe more on the right fuel. I say go for it. I would luv to thrash those turbo punks out there with an NA skyline.
cheapest option: sell it and atleast get a rb25DE :(
cheap option: buy half cut do a conversion
chepish option: turbo current car (but you still wont get that kinda power outta it)
expensive option: V8 conversion
Speaking of which, me and my brother are in the process of putting a VH45 into my R32... with a manual box ;)
Good luck with getting 180rwkw out of an NA rb20... a 150 shot of the nozzle would get ya there :(
Wobbz - What manual gearbox have you found to mate up to the vh45.  I take it your going aftermarket ecu?
None will mount directly to the engine. We'll get a custom adapter plate machined up to suit whatever box we finally chose (thinking a rb25 or z32 box (same internals)... but still have to work out shifter locations)..
As for aftermarket ecu, yes! I'm keen on running an autronic... they're (in my opinion) one of the best ECU's around, despite what some people say about wastespark (who usually don't have a ****ing clue). My brother has had great results despite others telling "no no, wastespark is bad... you need CDI if you want good power" etc.... yet his supra is making over 500rwhp with this so called shithouse wastespark using factory coils etc.
Although i havnt finished with my rb20det 280zx im already thinking about the next project.
Im seriously thinking about putting a built N/A rb30/25 into a 240z.
I was reading a zoom article a while back about building an n/a rb30/25. according to them they achieved a 32% power increase from just the head swap. that would equate to roughly 150kw at the fly from a stock 114kw rb30. Thats in the same region as a standard rb30et without any work just standrad 25 head on 30 block. not too shabby. Then think about upping compression, full engine balance, porting, cams, management etc.... I dont think 180rwkw is out of the question.
id love a balanced NA six pot capable of 12 or 13 second passes.
Take a look at this 240z vid. 3.1L stroker with triple carbs making 320hp.
http://www.bbgraphics1.com/73z/strokervideo.mpeg
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
