hello
i am an avid nissan skyline fan but i do not think that i am experianced enough to get a skyline mainly because of cost and experiance. i am 17 and have just got my P's and i am car hunting. what would be a good car to practise on. also i would like to learn how to drag and drift. i would also like to know where i might be able to go to see some drift events in victoria.
thanx
https://www.sau.com.au/forums/topic/71477-brand-new-car/
I was unaware that you could get your P's before your 18th birthday in Victoria.
If you really want a Skyline, get a 31.
They are solid, easy to find parts for, can be made to get up and boogey, and you'll find something suitable for under $5k.
Regular drag and drift events are held at Calder park.
https://www.sau.com.au/forums/topic/71477-brand-new-car/#findComment-1317986
how did u get your P's at 17 :|?
If you like drift the best then you should go for a 180SX or a S13 Silvia.
But if you must settle for a skyline i think the R32 would be mad for drifting. You could get one cheaply imported from japan. The only problem would be insurance. This is where SKY031's idea is better with the R31 because it will be cheaper to get insurance...
https://www.sau.com.au/forums/topic/71477-brand-new-car/#findComment-1318007
I say good on you for using your head and realising u arent schui when u start driving. Maybe wait until u got some experience in decent power RWD b4 getting too geed about drifting though
depending on ur budget I suppose I would have to say you might be able to get a more nimble and fun package if u go with the S13s. Black top sr20det is the pick or even a CA18DET for less and they are great fun, bit lighter than the cheaper skylines (however if u had more $$ also for mods more potential from R32/33). 180SX looks better me reckons (than S13 silvia)
Im like you but I love the skylines and RBs so I got the best of both worlds - RB20 in 180sx -sounds much better and great top end in lighter chassis. If u are a skyline nut also u could put any of the RB engines in later on!!
anyway lots of good ways to go just my ideas :)
https://www.sau.com.au/forums/topic/71477-brand-new-car/#findComment-1318065
r33 gts, is what i got last year for my first car... r32 gts is quite aiight too...
hat goes off to ya, for thinkin abt the future and insurance, and knowing that these cars
drive slightly differently to others...
i made the same choice to go n/a, and i'm loving it - all my mates are spewin over the
insurance and fuel prices, inability to handle boost, turbo problems, etc :)
that said an; r31, r32 gts, r33gts, 180sx, s13 are all very good beginning cars - and
with the money you save on insurance/fuel in the first few years it'll be even better
when you can throw in a fully worked RB, SR or something even crazier.
eug
https://www.sau.com.au/forums/topic/71477-brand-new-car/#findComment-1318197
    • Also sorry to hear this @DanielStone - I remember @SmoothLine well, he was around for a very long time and was one of the original members of this site.  God Speed Matt. Thoughts with his family and friends.
    • Nice car! Looking at your GTS; makes me wonder why I bought a GTS-t... Everything has been changed anyway. I should have just started with a non turbo model.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
