  • Replies 104
I was wondering if any of you guys have been on wakefield park before, and what times you pulled off.
It was my first time there and i managed a 1:18.3190 In a stock r33 gts-t, beat all the other "modified" skylines there.
what suspension etc do u have
the breaks tyres are fine... the tyres had only done about 3000KM but have been warn quite abit, still HEAPS of tread left. and i havnt noiticed any break fade, exactly the same as when i got there.
I did abit of drifting so the tyres are abit more worn than other ppl, but i only did 28 laps,i went out for 3 sessions instead of 4 to give the car a break to cool down.
i've bene out there! i LOVE that track! but at the moment i suck at it!!! i'm only doing 1:19:03 and thats with me timing myself on my phone while driving! ;) so who knows how accurate it is :)
i've been out there about 3 times! First two times - crap tyres all round.. third time i had decent tyres and the back and shit ones still on the front (stock measurements for all tyres).
Silv - i've only changed my brakes once in the three times i was out there, and my tyres once... but i haven't been going all out! Had a chat with Abobob ( :) ) and his car is stock compared to mine which is almost stock! so i figure i just don't push my car hard enough!
will be back out there within the month with sway bars and more aggression!! fingers crossed i get close to 1:15s :D
I saw your car on the wall there Moanie. One of my mates pointed it out, he said, "hey look it's a shit car like yours!" grrr... lol
A mate of mine with a stock s2000 on stock rubber managed a 1:14:04. I guess power isn't everything. *shrugs*
not necessarily cause of the weight in the chassis for 180sx - more depends on mods
1st track day of mine anywhere (and still is) was at Wakefield, did 1:17 in RB20 180sx, 9psi, CA intercooler and radiator pathetically tiny and water temp peaking after 2 hard laps - return with me new cooling mods me reckons :wassup:
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
