  • Replies 104
There goes my tread :-(
U BARSTED !!
j/k
eeek.!!! Sorry not what i wanted to do. Its pretty quiet in there. Keep it rolling along here...the other thread is there mainly to get a feel for what sort of mods do what to lap times if thats your thing:)
Cant wait to get back to Wakefield in May, back in Sydney for a month woth work.:rofl:
:rofl:
Cant wait to get back to Wakefield in May, back in Sydney for a month woth work.;)
I was j/k i was just curious how how other skylines performed on the same track, and u answered it. :D
With my former GTR, 1.19 in the wet. Mods, PFC, FMIC, road tyres with Whiteline sways set to stiff (not good in the wet).
I was faster with the exhaust restrictor on! HAHAHA! Spun off a few times an learned a valuable lessons:
1. Don't downshift while cornering in the wet.
2. Brake in a straight line in the wet.
3. Don't jerk the car around too much in the wet.
Getting an MR2 turbo next. Interested to see how a RWD mid-mounted car will perform around the park.
Well my first time at Wakefield (2nd trackday ever, or basically I first because my brakes died after 2 sessions at EC the year before) I only managed a 1m21sec and that was in the last handful of laps before the day was over. It took me about 40-50 laps to realise that I could push my car soo much harder around corners (with some steady understeer :rofl:). Afew laps with Duncan (whom gave me 2 good pointers) and I dropped an easy 6-7sec but by then my tyres were scrap.
In 3 trackdays (~150 laps) i've never spun, actually never even had any oversteer at all so I know I can push harder next time (with decent rubber) if I can get the balance right to dial out some of the understeer.
I've now done 3 circuits.
Eastern Creek = Big power, big brakes.
Wakefield = Suspension, skill.
Oran Park Sth = Precision, grip.
I've spun twice at Wakefield.
1st time in an R31 GTS2 (not my car, oops)
2nd time my car, tightened up the diff.
Went from 12lb to 85lb lockup.
1st lap, coming out of the stop/go corner in the middle, gassed it and woops.
Diff was worth 2+ secs a lap
Hooks
Yeah, thats the corner I mean.
The other one I have trouble with is the one coming on to the straight.
I always seem to turn in too late and screw up the apex.
My favourite bit is the left, right, right, sweeping right, up the top.
I like to hurl it into the 1st left/right, slide it right out to the ripple strip on the downhill right, and then hang the arse out around the sweeper with the drivers side front wheel up on the curb.
Huge fun!
Hooks
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
