  • Replies 104
My best time is 1:16. Went out yesterday but only managed a 1:20 (consistant tho).. My brake pads where cheap and nasty (aka.. fadeeee so I was braking very early)... plus my tyres can't put the power to the road or grip well under brakes.. all in all not too bad at all! merli is right, its easier to drive a slower car fast! My accerator pedal was like a handbrake!
I had a ball.. Was a little frustrated about the brakes being spungy and a bit meh but the car was running better than it ever has! Was weird to be back out on the track, its been a while.
I will swap out the pads for sbs ceramic pads, flush the fluid again (did it on saturday) and then throw on some decent tyres and aim to better my 1:16.. which should not be too hard.
Bendix are a street pad, they hold up to wakefield park "okay" but you need to give them a rest every few laps.
however they chew the rotors ALOT more than most other pads. So yeah you save on pads but your rotors wont last as long.. meh
I used race brakes RB74 and they where fantastic, the sbs are better again. You get what you pay for, i was racing on $150 pads on the weekend and will change to the sbs pads ASAP!
With the rb74's my car was on the track at wakefield for a full hour (first me driving 20 minutes, then someone else then me again.)
no just fronts
for that kind of money you may as well fork out another $30 for Project Mu HC Titan Kai Pads. One of THE BEST pads you will ever come across and that's speaking from first hand experience. They work from cold and are rated to 800 Degrees. This is awesome for a performance pad considering Endless's top of the line CC-R pads work in a heat range of 150 ~ 800 Degrees.
Project Mu pads are also readily available in Australia.
you wont look back
Titanium Carbon Metal Composite.
http://www.project-mu.co.jp/e/product/hc-t.html
On the topic of brakes, Race Brakes now distribute a brand called Galfer. They make Braided Brake Lines for around $450 for a full set. Very good lines and well worth the money to improve your pedal feel.
on brakes I just fitted a set of Nismo lines I picked up in japan. having previously bought aus made ADR approved lines I can say that the nismo ones are much nicer still. they are a teflon line covered by a stainless steel braid which is then sheathed in teflon covering. this prevents dirt working into the braid which can be a problem. oh and they were about half that $450 price....
also I bought some Endless brake pads whilst in japan which I'll whack in this week. the GTR already has endless pads on the rear and I dunno whats on the front. it stops very well but needs 1 or 2 stops when cold to start working.
I have previously found the Endless pads to be excellent. have also tried some project mu's but can't remeber which type (they have quite a few). they were quite good too.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
