Ares Speed closed for the last 2 weeks?
funkymonkey
 Share
They also borrowed a kit from my mate to copy. He has been trying to chase them up for mths about it. I guess he will never get it back.
Nathan and Neil are one of the most dodgiest people out there.
I know where they live, over this week end I'll snoop around to see if they're still living there. I hate DODGY FARKERS.
Neil one of the owners said they wholesale only now and are operating from the back of the panel shop next door.
Tried to contact Mario who built and hosted their site? His Supra was always getting bodywork done there, might be of some help?
You will find his supra get work done at Millenium motorsports now if that helps. Millenium get thier bodywork done at DMD. ;)
I know this, but it was easier explaning it the way I did :rofl:
SupraMario here on friends account ...
Millennium is a performance workshop
theyre not an entity like ares / dmd that do full show cars and what not,
theyre the same as subzero / APC / and the like ..
My supra has had its work done all at ares, and any future things ill sort out through panel beating friends, not DMD.
The millennium cars you might be referring to will be the workers there that had work done by DMD, its a bit far fetched to say that all work is referred there..
then without gossip where would most forums be :)
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
