Hey Cam,
Nah man pulling it off was easy - if you've got the '95 model with the airbag in it, they're prone to the clunking noise, there's actually a rubber mounted cast iron weight in there, over time the rubber obviously degrades and leaves the iron weight to clunk around - pain in the ass it was!
So I ripped out the weight (after a few months of searching for the tool!)
managed to find a Torx Tamperproof Socket set T10 up to T60 i believe (1/4" and 3/8") :)
thanks again Kym for the offer of a lend :) thought i'd pick them up seeing as i might need them for something in the future and you can never have too many tools.
if anyone needs a lend of a socket let me know :D
Strich - did you have any problems pulling off the steering wheel? Mine's making a wicked heavy clunking noise. Hope the airbag don't go off in the meantime! :)
Hey guys I posted the thread on this year ago..and I do have the tools....
Bought them from Repco as a set for $19....
The airbag is safe . It sits inside its own compartment and this weight sits suspended above it.
One thing I noticed over time without it the steering wheel vibrates with the car. Not noticable with the weight on. This is not fixable as you have to get a new steering , can't weld rubber :)
al
what tool does it take to get a 95 streering wheel off with an airbag, its making that clunking noise and i had to rip the fuse out cos it kept turning on the horn around corners...?
Will the airbag bust out if i take the steering wheel off?
Tamperproof T50 socket, i should be doing this to mine in the next week or so, i'll see how i go with it :)
disconnect the battery and take care with the airbag.
You don't need to disconect the battery, its a mechanical issue. Nothing electrical you will get near no sensors or anything.
al
