Well just got a quote for my rebuild (RB25DET), was wondering if you could all look through it and give me ideas on what is priced good what not. and altertnatives?
ACL Mahl Forged Pistons with rings(20thou). $1400
Tomie metal Headgasket................................$550
Nissan Gaskets..............................................$200
Bearing Set (Tri-Metal)....................................$300
Welsh Plugs....................................................$80
Machining, close & hone, shot peen ..............$2000
Rod Bolts........................................................$280
Head Bolts......................................................$200
Labour charge
28 hours........... $2150
Totalling... $7290
Also i am only planning on getting 250rwkw out of the motor... so the stock rods should be up to the task?
Is this about right? anything i should change? any ideas where i can get parts for cheaper from... ?
Thanx in advance
https://www.sau.com.au/forums/topic/71572-rebuild-overview/
you probably don't need to spend that much on a headgasket... imo
and you could probably save a couple of hundred on the pistons by going Arias or Venolia
stock rods will be fine for 250rwkw
other than that it sounds about right, good luck with it
btw what happened to the old engine?
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1319792
Don't skimp on the bearings.
Either go Nissan or a set of King HP Bi-metal bearings or Clevites.
What brand are they?
KING HP rigns a belll, not 100% sure, but will double check...
Also i was thinking, no need to go for metal head gasket as i wont be pushing that much power, to really need one?
Rebuilder told me vernolia pistons are abit thin or sumtin, and doesnt like them?
But alot of people seem to be running Arias with no problems, can anyone give me a price on arias 20thou over?
Turbo seals went, oil went to the intake in the engine detonated...
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1319959
$2000 for machining ? a bit on the rich side i thought , then again depends on what they are going to do .
Does that include cil head work and crank regrinding , for that price it should and its still high .
I had arias pistons in my rb26 40 thou oversize no probs , trade price around 1000 - 1100 including rings .
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1320014
Machining including head work needing to be done... valves need to be reset...
The quote was from MRC
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1320031
$7000, if that includes motor in and out of the car.
Then thats a fair price, i paid a similar figure for mine which is very reasonable.
including
Arias pistons,
GTR Rods - which i reccomend you factor in as they are cheap as, and you'll have a tough bottom end then indeed. With room to go for more power later
and all the other stuff :P
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1320220
including
Arias pistons,
and all the other stuff :(
My rebuilder said i require a GTR crank for GTR rods???
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1320613
If thats what he said, its time to go and find another engine rebuilder that actually knows RB motors.
Its to much money to risk IMO
You do not need to use a GTR crank to run GTR Rods.
My RB25 uses GTR Rods with stock 25 crank.
You run the GTR crank it makes it like 2.6 or 2.7 ltr, cant remember which.
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1321147
Rb 25 is the same bore as rb26 , the diff is the stroke 71.7 mm for rb 25 ( 2498 cc) and 73.7 for rb 26 (2568 cc ) 20thou over (.5 mm ) will give you extra 30cc aprox .
You have to make sure they know what pistons to use as well to retain your compression ratio of 9 to 1 . Unless you want to change that but make sure you know what you are getting dont relay on them .
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1321434
The pistons will retain the compression ratio... and he said i can put gtr rods in, so he is goign to be pricing that up for me now...
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1321736
rocketindustries.com.au was where I got my pistons... (great price and service)
cams from nengun.com (great price but delivery was very delayed)
everything else, water pump, bearings, timing belt, gaskets etc was all from Nissan but I can't remeber which one... I think it was Blackburn
https://www.sau.com.au/forums/topic/71572-rebuild-overview/#findComment-1323707
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
