a PAIR of 32 gtr wheels...
WHITE R32
 Share
hey guys id like a pair of r32 GTR wheels not a set of 4...
paint or anything doesnt worry me too much cause theyll be repainted anyway but they must be straight and have no flat spots or dents.... and must be "cheapish".....cantrecaps are usually good to have too... tell me what you have and ill see what i can come up with... im near brissy and would prefer somethin local but im willing to think about interstate etc... thanks guys.....
I have pair you can have for $300, one was repaired in the past but on inspection you will see how very minor it was and I only got it done cause I know a workshop who did the weld for $25 for me.
Whats your email I will post pics?
No Tyres, No Centre Caps. Other than that their in fantastic condition.
Jon 0413 244 862
 Share
    • The r34 gearbox is like $3400/3700 landed from Japan sometime last year.   Contact jessestreeter.com for info and quotes. From memory the navara gearbox needs input shaft machined down as I looked into a while back and there's a thread somewhere here from 2018-2021 about it. Depends on what your doing with the car maybe worth the dollars to go cd009 or a 8hp50/70.
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
    • It's used in the GT-R, GTST/GTT, and Z32 VG30 NA + TT versions. Nissan still makes them new, they're not cheap but they're not expensive either. Personally I would just get something direct-fit and be done with it but I'm not that handy at fabrication.
    • FS5R30A the nav box isn’t it? I did think about those. Any issues? I wondered if the bell housing off an rb30 patrol would work as they are the same gearbox but with a transfer I believe.
