Hi All,
There was quite an interesting dicussion of oil filters in the maintenance section awhile ago.
In a similar vein, I have search for some discussion of fuel filters but drawn a blank. They get mentioned an awful lot, but usually its 'replace your fuel filter'. Soooo, is there anything to choose between the various fuel filters one can buy? Should I just grab the genuine article from Nissan, or will any supercheap yum-cha brand do?
Thoughts and suggestions are welcome :(
Lucien.
https://www.sau.com.au/forums/topic/71633-fuel-filters/
genuine nissan is (always has been) the go for me.
I wouldn't bother with aftermarket ones in this case. unless of course you had a 10000hp fuel pump and 1000cc injectors and the stock filter was a restriction.
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1320812
As mmmgtir mentioned the OEM fuel filter is still pretty good & quite efficient.
When I first bought my car I was experiencing a pressure drop of around 2.4+psi, the car had a cheap fuel filter. I had it replaced with a Nissan item. Now, although Im only running just under 200rwkw, Im told theres only a pressure drop of under .8psi.
Basically, you would only want to upgrade to a performance one if you want to decrease the pressure drop across & near the filter. Performance filters normally have a pressure drop of <.3psi & filter down to the 10-30 microns range (not sure what the OEM is rated at).
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1320944
Interesting. I just spoke to Crows Nest Nissan to try and order the OEM fuel filter. The part number they have comes up as no longer being produced, and there is no updated number attached.
Does anyone have the part number -- one they have actually used, not just ripped from FAST because Crows Nest Nissan is using FAST -- for the R32 GT-R fuel filter ?
LW.
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1321079
Can that part also be used on a 2001 R34 GTT??
With the proviso that's it's better to have the VIN of your car (from the Nissan ID plate on the firewall), according to FAST the PN for the fuel filter on your car is:
16400-41B05
Suggests the filter is different to the R32 type.
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1321681
16400-41B05
SteveL PM SENT.
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1322076
The OEM R32 GTR fuel filter PN is:
16400-72L00
but this was superceded by PN:
16400-72L05
and that was further superceded by PN:
16400-53J10
I will run those past Troy and see what turns up.
someonestolecc: Make sure you ask for Troy. Apparently they do COD; personally I just go and pick it up. Your best to do your research before hand and have part numbers handy as they are obviously not import specialist: they are just willing to help so cut them a little slack ;)
(B1) MR_fanny: I had a look at the Ryco part numbers and its not the same as the GTS-t. They run Z200/201/202 (or something) but the GT-R is listed as completely different. Sorry for not being specific, I CBF'ed finding the Ryco listing :(
pkblade: Given the Ryco part numbers are different, are you sure about that?
LW.
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1322395
Im 100% sure.
According to the Ryco listing Cubes provided :) the 16400-53J10 is the equivalent to the z387, which also, can be used on all RB20's, RB25's (no mention of the Neo), & RB26's.
https://www.sau.com.au/forums/topic/71633-fuel-filters/#findComment-1322849
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
