hi, if you want to do it the cheap way and have a couple of hours spare - heres how.
goto bunnings etc and buy a 50mm pvc pipe with a 45 degree bend- take your gauge with you to check for good fit.
cut a wavy curve into one end that fits the profile of the a pillar - its a little tricky and takes a bit of filing
take a pice of metal about 100mm long, 15 mm wide and 1 mm thick, the piece out of the expansion slots in the back of your computer works good.
bend each end of metal 90 deg and up about 15 mm and fit your new bracket inside the pipe
drill a hole either side of pipe and countersink it, rivet the bracket to the pipe.
fit pipe and bracket to car, drill a hole through pipe at 90 deg to bracket - so you can drill through it (making pilot hole in pillar) and also to put the screwdriver into so you can screw gauge hole(pipe & bracket) to a pillar.
get your mum or missus to sew a leather sock that is the same diameter as the pipe and 230-40 mm longer than pipe. it will be sewn with seam on the outside. turn it inside out so that the seam is hidden.
fit sock to gauge holder , tuck in near edges that is against a pillar and glue it.
there should be be some over hang at the end where you will fit the gauge.
push the sock over hang into gauge holder then fit gauge into it, gauge should be a snug fit and hold sock in place, if not wind some tape(e.g. insulation tape) around gauge to increase diameter until it makes a snug fit.
then if you've done a good job you will have a leather gauge holder that looks really good.
P.S. you need to be careful or you will end up buying a plastic gauge holder to cover up any mistakes. oh yeh, std disclaimer if anything goes wrong, do it at your own risk ....
I will post up some pics of mine sometime ... it cost me about $5 to do,for pipe and leather offcut.
https://www.sau.com.au/forums/topic/71645-r32-a-pillar-pod/#findComment-1331850
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
