  • Replies 102
Lol what a mad keyboard warrior.
Sadly i'm not as stupid as you may think. Sadly; because people like you need to believe that anyone that thinks the same way i do is stupid, simply because you cannot conceive that people may share different opinions. It makes a dictatorship easier, shout down any opposition.
My opinion is not only based on bad encounters, but on what i know of my various mates who are arabic, and their mates. Like i said, these guys are good to me, i consider some of them my close friends, but the morals they have seem like they're from a different planet from mine.
At 19 i doubt you're in a position to be the most wordly and informed guy to be speaking, at that neither am i, but at least i'll admit it.
Just realised too that you're doing a law degree which means that you're learning to be a professional argumentative bullshit artist (sorry another generalisation), so i'm not intent on changing your opinion, mainly because i don't care, but also because i don't really want to. You're entitled to your opinion as is everyone else on this server, and unlike you i won't go calling you a stupid ignorant moron for believing the way you do. If you read through this thread you'll see there are plenty with different opinions.
on a side note thats a pretty funny jpeg babylon.
Anyway back to the topic at hand, these personal slanging matches have even less to do with the original topic than what it was turning into anyway.
ps how good was big brother uncut.....well not that good but much better than normal big brother!!!   :P
HAHAHAHAHAHAHAHAH :headspin: DOUBLE OWNEDDDDD
Could not have said it better myself,
Heres an idea for all the lebanese performance car drivers. Go to a souvineer shop buy a Zip up or jumper with an Australian Flag across the front about $20 bucks and wear it when your cruising around sensibly in your car. Think about it What looks better to the cop who is about to defect the christ out of you A FLOURO yellow puffy KAPPA jacket or the above Australia flag one.
Its worth a try and also keep your smart arse mates in the back quiet, after all they arent going to chip in with the fines and expenses
GOOD LUCK FELLAS I am trying it myself. :kick:
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
