Right clutch for gtr?
By TurboTapin · Posted
Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston. -
I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera. With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6. Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap. -
I think it's the same. It all comes from the same shithole refinieries in SE Asia.
I was referring to the final octane level achieved once 10% ratio of ethanol is added.
