Originally posted by nismoR34
I think there is a common issue here that we may be overlooking.
Mine too [r34] seems to leak out some air, i notice it after i have been driving. Ie switched off motor etc. Is it our fuel?, octane? Humidity? Why does there seem to be a leaking of fumes? It's a little odd to me. It almost appears to be an issue that should be addressed when complianced, me thinks :zap:
hmmm...good point, coz the inlet thing has to be replaced when complianced, right?
when i drive for a while , especially during the day, i notice a hissing sound from air leaking. also i notice fuel has been dribbling down the side of my car! the thing that has me stuffed is, if the air is being sucked into the tank, then why is there fuel coming out of it...even when it is close to empty?
so my next question is...is it the cap? will replacing it stop the leaking, or is it the inlet?
i have no idea how a feul tank and fuel pump works, and to me is sounds flawed if it has all this sucking pressure with a cap that is suppose to be sealed? would mine be sucking fuel easier because of this?
is this msg too long? are my ramblings making any sence? or is it because ive been up for 24 hours??? probably. i dunno, im going ta bed
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
