Very Regretful Sale
Owner is starting a new business and needed to buy a car with reasonable laugage space to transport goods.
YOUR CHANCE TO OWN A UNIQUE KAI CLASS SPORTS CAR.
Features as follows:
Aftermarket:
- Suzuki Sport upgraded turbo
- Suzuki Sport upgraded ECU.
- Suzuki Sport upgraded injectors.
- Stainless steel exhaust.
- Blitz blow off valve.
- Speed restrictor removed.
- Aftermarket rims
- Serviced every 5000kms.
Standard features:
- Rear wheel drive.
- 80,000 kms
- 11 months registration. (Victoria)
- RWC
- Recent cam belt & clutch change.
- Four way roof (hard top, t'top, targa, full convertible).
- Cordoba red.
- Capable of achieving 400km per $20.00 tank full of high octain fuel.
- Manufacture Date: Late 1993
Price: $18,000
Contact:
Malcolm Zammit
0403289669
https://www.sau.com.au/forums/topic/71715-fs-suzuki-cappuccino/
At Winton the Cappa actually overtook 2 R33 Skylines (had light mods: FMIC, Exhaust, Boost). Due to it's size and low centre of gravity it really handles great. Winton is a very twisty track so the Cappa did well, especially when it had shitty tyres, with alot of sidewall flex and not enough grip. With new good rubber it would have done even better. Down the quarter, the Skyline would always win.
All depends on the driver really.
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
