sik'n'shit!!!
seriously though, so are these drum brakes or discs brakes pads that i'd be needing. coz i've used the mu's secret d1spec pads before in a rx7 and they were really good. just wondering if i could use the same type again. or if it was drum ones i needed.???
cheers
I thought that all Rb20 cefiros are either solid disk on non turbo or ventilated disk on the turbo cruising models at the rear and the hand brake just pressed on those callipers . Can't be sure about the rb24 tho as i didnt even know they existed in a cefiro
:headspin:
Yo,
On my severe- tos I found that It was like the R33 setup
Brake pedal = Disc & Cariper
Hanubrake = Internal Drum setup
For sickness make sure it is adjusted up tight and ya got meat on the pads.
Does anyone who of a shop who sells them drift-spec drum shoes???-In aust
I guarantee that the handbrake on your ceffy activates a DRUM mechanism, The likelyhood of finding "sik, fulli sik" brakes SHOES in australia is bugger all.......I have always found that good adjustment of the brakes works a treat.....i have never had any problemms with handbrake entries in my cars.
