Greddy turbo timer + english manual = $129.00 + free delivery (Available in Black or silver)
Greddy Profec B specII + english manual = $479.00 + free delivery (Available in black or silver)
- Limited time offer and availability.
- No risk of getting caught by custom.
- Tax invoice will be provided. (I have ABN)
- Support the local industry.
*** WILL TRY MY BEST TO MATCH ANY PRICE AS LONG AS IT IS A GENUINE QUOTE ***
GREDDY AUTO TIMER
-It is compact in size measuring 8cm x 8cm and 2cm in height.
-Comes in new casing model with internal flashing LED pattern.
-It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
-Able to automatically calculate and suggest the cool down time.
-Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
-Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
GREDDY PROFEC B SPEC II, ELECTRONIC BOOST CONTROLLER
-Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI).
-There are optional warning and boost limiter functions that can be programmed to offer much more control.
-The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
-This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
hey mate...interested in ur turbo timer...can i pik it up in person tho n pay u cash the same time at all?? plz let us kno asap! cheers
yes you can. i have pm my mob no as well.
GREDDY AUTO TIMER
Speed warning mode
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
