GREDDY Timer$129, Profec $479, Catch can $159.95. Items in australia. Ready stock!
Greddy turbo timer + english manual = $129.00 + free delivery (Available in Black or silver)
Greddy Profec B specII + english manual = $479.00 + free delivery (Available in black or silver)
- Limited time offer and availability.
- No risk of getting caught by custom.
- Tax invoice will be provided. (I have ABN)
- Support the local industry.
*** WILL TRY MY BEST TO MATCH ANY PRICE AS LONG AS IT IS A GENUINE QUOTE ***
GREDDY AUTO TIMER
-It is compact in size measuring 8cm x 8cm and 2cm in height.
-Comes in new casing model with internal flashing LED pattern.
-It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
-Able to automatically calculate and suggest the cool down time.
-Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
-Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
GREDDY PROFEC B SPEC II, ELECTRONIC BOOST CONTROLLER
-Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI).
-There are optional warning and boost limiter functions that can be programmed to offer much more control.
-The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
-This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
GREDDY AUTO TIMER
Speed warning mode
 Share
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
