GREDDY Timer$129, Profec $479, Catch can $159.95. Items in australia. Ready stock!
Greddy turbo timer + english manual = $129.00 + free delivery (Available in Black or silver)
Greddy Profec B specII + english manual = $479.00 + free delivery (Available in black or silver)
- Limited time offer and availability.
- No risk of getting caught by custom.
- Tax invoice will be provided. (I have ABN)
- Support the local industry.
*** WILL TRY MY BEST TO MATCH ANY PRICE AS LONG AS IT IS A GENUINE QUOTE ***
GREDDY AUTO TIMER
-It is compact in size measuring 8cm x 8cm and 2cm in height.
-Comes in new casing model with internal flashing LED pattern.
-It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
-Able to automatically calculate and suggest the cool down time.
-Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
-Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
GREDDY PROFEC B SPEC II, ELECTRONIC BOOST CONTROLLER
-Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI).
-There are optional warning and boost limiter functions that can be programmed to offer much more control.
-The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
-This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
GREDDY AUTO TIMER
Speed warning mode
 Share
    • Dose unofficially becoming R33 god
    • I would rather buy from aliexpress than whatever that "shop" is. Avoid like the plague.
    • Sounds like, to me, if you do some geometry calculations, you can fit a hoist in there
    • New dampening settings are much nicer or crappy roads, I've also noticed no difference when throwing the car around on smooth twisty roads In other news: Idle hands are the devils play things, or, more correctly, my typical while we're in there 5hit, and too much time on my hands with online shopping  Some new purchases for the 2.5 swap Fancy pants new 32mm triple flow radiator, because the old radiator is old and needs to come out for the 2.5 swap anyway Gates fancy pants water pump, because recommended with the new radiator  Plus a new silicone coolant hose kit,  because old hoses are old And a sump baffle thingo, because while I won't track the MX5, I'll probably track the MX5, maybe, probably......but, while we're in there anyway, as the FWD 2.5 sump needs to gets replaced with the RWD 2.0 sump, so, yeah I am loving driving the MX5 around everywhere, the poor old Bogan Cruise Ship hasn't really moved in months
