I've had my r33 for nearly a year and have been meaning to ask this question since i bought it. I found a red road flare mounted under my glove box. Just wondering if they are in every skyline and also if it would still be ok to use (as its about 10 years old now i'm assuming).
Finally if i get drunk and decide to do party tricks with it do i just need to pop the top off to get it started?? (note: you will not be held liable for any stupid crap i do :rofl: )
Cheers
https://www.sau.com.au/forums/topic/71749-flare-in-my-r33/
All J cars that I've been in in Japan have them. Dono if it's regulation or something but yeah they have it for safety.
I guess when they come to Aus they stop being for safety and start to be for fun :rofl:
Don't pop any near the sea I think that gets the coast guard/rescue people goin.
https://www.sau.com.au/forums/topic/71749-flare-in-my-r33/#findComment-1323305
They work fine dude, just lit up a couple last week : )
Pop the top, and spark it up like a match (there is a section there to do it)
so its U who steals them before owners get them!!!!!
my old car had one, other than that i have rarely seen them, i guess the importers have all the fun!!!!!!
https://www.sau.com.au/forums/topic/71749-flare-in-my-r33/#findComment-1323419
Check out the owners manual, i was curious about it so i flicked through that. From what i understood from the cartoons, it's for those occassions when your car breaks down on a railroad and you need to signal the train to stop. Or you could get off your ass and push the car.
https://www.sau.com.au/forums/topic/71749-flare-in-my-r33/#findComment-1323443
thats why the r33 are so much better lol...maybe you could purchase an aftermarket super flare just to outdo us.
Yeah i'll have to think of something interesting to do with it. Maybe douse a mate in bourbon and throw it to him....hahah jokes.
guess i'll just keep it, never know when it might be needed, carjacking for example
https://www.sau.com.au/forums/topic/71749-flare-in-my-r33/#findComment-1323619
dang i should have got an R33 and drive a whale
:kick:
https://www.sau.com.au/forums/topic/71749-flare-in-my-r33/#findComment-1323658
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
