I have read hundreds of threads about whether an rb25 turbo on an rb20 is a good upgrade or not.
I have an r32 and it seems relatively responsive, still on stock boost, but the midrange seems shit and just revs out with no real power. I need to get it tuned and i have a 3" front and dump pipe and hi flow cat to join onto my old 3" cat back system.
The other thing i read was that if you put on an rb25 turbo they get very fuelly, so i was wondering if you got it tuned after if it would fix this problem.
basically i want a daily that i can put my foot down on the odd occasion and feel it kick me back in my chair and beat commodore assholes ha ha!
any help would be good cheers
https://www.sau.com.au/forums/topic/71750-rb25turbo-on-rb20-q/
  • Replies 54
Posted Images
I am not sure I understand the question, but I will have a go......
The RB25DET turbo produces 10% more airlfow at 7 psi, than the RB20DET turbo does at 10 psi. So if you bolt on an RB25DET turbo and use the RB25DET wastegate actuator you will get 7 psi and about 10% more power. However if you use the RB20DET wastegate actuator on the RB25DET turbo it will produce 10 psi and you will get 25% more power.
That is provided you have the support parts (intercooler and exhaust) in place to handle the increased airflow.
If you really want to get the best from the increased airflow you really need to tune it. R32GTST's have an easily chipable ECU. Either that or an SAFC (or equivalent) will do a reasonable job of removing the exccessive richness that the standard ECU provides whenever the airflow is increased over standard. There is another 15% more power to be had from simple tuning.
That's more than enough to give a 255kw Commondoor a thorough thrashing.
Hope that answered your question:cheers:
Hmmm, very impressive Ronin. We have same mods but the cam gears.
How much difference do they make on a RB20. Did you do a before and after power run?
You are running a bit lean there, the power must of came down a bit once the fuel pump was changed. I had 137 rwkw but was running flat 14 AFR and after the fuel pump change it went down to 130 but very rich. The car was still pretty stock then. :D
fark ...
my r32 with stock turbo only pulled 135.5 rwkw on standard boost .. with the only mods ..
hks filter,
hks full exhaust,
standard copper ngk plugs (non iridium)
............ now that i got the fmic and new bov ...will i get more power increase??
also i have the r33 stock turbs as well but not fitted yet and i dont know if this is worth the hassle of doing without causing strain on the engine ..???
also could i boost more if i used the r33 turbo but using the r32 actuator?? will it cause damage to the turbo / engine?? and how much boost could i run? and wot power figures should i expect?
cheers
With a fmic + bov + r33 turbo, id get it tuned then u cud run probably as much as u wanted, but id say to keep it safe keep it around 1bar for racing and just normal say 10psi for daily driving! Yes the r32 actuator goes onto the r33 turbo no problems aswell.
Actuator regulates the boost level, (ie rb25 actuator = stock 7psi, rb20 actuator = stock 10psi)
rb25 turbo is just bigger than the rb20 turbo really.. series 1 r33 turbos are the strongest (but usually are older remember). Actuators generally come with the turbo, if not put ur rb20 actuator on there (or maybe do that anyway...)
rb25 turbo = $400 (+ install.. $100-200)
FMIC (inc install) = $700-1000
So your looking $1500ish for it all done, if your exhaust is done ull notice one hell of an improvement :)
Actually i wouldnt run too much boost with the rb25 turbos. S2's have a plastic compressor wheel, and both have ceramic exhaust wheels, so its possible to drop the wheels off still. I was running 16psi constantly with my S2. Before i had it tuned, and with a small boost leak which lost a lot of bottom end i still ran a 13.0 @105mph with a 2.1 60ft on crappy tyres. That was in a 180sx, but a R32 gts-t isnt that much heavier, so you can beat most commodores if thats what your worried about. One of the biggest differences was getting it tuned, top end was a little better, but the most noticable was normal driving and the mid-range... fuel ecomonmy was much better also. As someone said before, your clutch will go quickly, mine lasted about a week
Series 1 turbos are not really any stronger as both s1 and s2 have ceramic turbine wheels which is the weekest part of both turbos. The S2 has a plastic compressor wheel which gives better responce.
Is it possible to put a t28bb onto an rb20det?
If so, would it be better than the rb25turbo?
Sorry, i must be a dumbass.. i still dont really understand the role of the actuator.. i understand that it regulates boost.. but i dont understand how the rb25 one is better than the rb20 one. How do they differ?
A t28 smaller than the turbo you have already got.
Its not a mater of one actuator being better than another. is all the actator does its push the wastgate open once a certain amount of boost is reached. An rb25 actator is designed to open when it sees 5psi where as a rb20 actuator will open when it sees 10psi.
cheers
You are running a bit lean there, the power must of came down a bit once the fuel pump was changed. I had 137 rwkw but was running flat 14 AFR and after the fuel pump change it went down to 130 but very rich. The car was still pretty stock then.    :O
I'm fairly sure you want to run a 12:1 AFR
putting a T28 from a S14-S15 on a RB20 would be useless exercise.
it will cost more to fabricate a new flange for your manifold and I'm not so sure if would actually be called an UPGRADE.
actuator.
the RB20's don't have a boost controler at all.
the factory boost setting of 10psi is set that way due to the spring that is in the actuators diaphram (that round part at the front)
that spring is hard enough to keep the wastegate closed enough to provide the engine with 10psi of boost.
The Rb25's have a solenoid that controls boost. this solenoid is controlled by the ECU.
so the actuator diaphram has a spring in it that is weaker than the RB20 one.
the spring alone can only hold 7psi.. and the ecu/solenoid combo work together to provide more if needed.
so when people upgrade their RB20 turbo to an RB25 turbo, because their stock engine doesn't have a boost controller, they use the RB20 actuator.
this means that they can still get 10psi with no other boost mods on the new bigger RB25 turbo.
as Sydney kid said earlier, the RB25 turbo will flow (meaning produce) 10% more at stock 7 psi than the RB20 turbo does at 10 psi.
so even if you use the Rb25 turbo and it's own actuator, at 7psi you will have more power than with the rb20 turbo at 10psi.
but use the rb20 actuator on the Rb25 turbo so you have 10 psi on that as well and you end up with a 25% increase in power/flow at same boost on the new turbo.
does that help?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
