  • Replies 54
Posted Images
I also installed 3 inch exhaust from the dump pipe ( 2 resonators only, no cat ) and K&N pannel filter. With the RB20DET actuatoer i was hopeing to lock boost at 10psi but the boost goes up to 11.2psi and i have huge power loss.
But with RB25DET actuatoer it holds 7psi through out the power curve and give good power.
Explain the power dip, as u mention some thing about the computer?
dude ...u may wanna check your intercooler piping clamps and make sure they are tight and not leaking ....
check for vacum leaks etc .. and u may wanna re-set ur ECU especially after u have added extra bolt - on modz.
also check the exhaust manifold for cracks and u may wanna replace the gaskets etc... if u have not done that yet ..but if igured u have since u replaced the turbz already ..
  • 7 months later...
finally tried fitting my rb25 turbo onto my rb20 yesterday.
with no success.
seems my water and oil feed banjo bolts on my rb20 turbo are smaller then on the rb25 turbo i got.
all i can think of is that my rb20det engine is a series 1 engine.
is it just a case of using the original rb25 turbo banjo bolts?
or will i need the rb25 water and oil lines aswell?
any info could help me
cheers.
anyone here with first hand experience with a rb25 turbo onto a series 1 rb20 engine?
Edited by RSTME
RSTME- check the link bellow. I've done this a while back and you got all the info in there.
http://www.skylinesaustralia.com/forums/in...5+turbo+upgrade
Hui - My car is Auto as well and I haven't had any issues at all.
Edited by nedb
no.. I have a s1 engine (1989) rb20, and was able to use exact same factory fittings to fit rb25 turbo.. No other changes required.
So either your "rb25 turbo" is not in fact one, or well I don't know :P
it is a rb25 turbo steel front wheel and ceramic rear wheel.
nedb. thanks mate,ill ring around for some new lines.
  • 3 weeks later...
k,i got $120 connections for the new lines,r33 turbo is on now
i have a manual boost controller(T-piece thing)
took it for a spin, hit over 20psi so i turned it down.
also noticed it now runs heaps rough(like an old v8)
will it idle normal when i get a SAFC and get it tuned?
also i noticed the last bolt for my exhaust manifold is missing.
Now ive turned it down so far it only boosts to 5psi in first gear at 5000rpm, then easy makes 15psi in 2nd at about 4500-5000rpm.
automatic
r34smic
3"dump/frontpipe
3"highflow cat
3 1/2" fromt cat-back.
im using a rb20turbo actuator aswell,should i try removing the T-piece boost controller?
the hose from my actuator runs to the T-piece then to the compressor housing.
is that right?
Edited by RSTME
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6.  7.  8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
    • Yeah, playing with naturally aspirated is not smart bang for your buck power wise, but then I've never been known for being smart when it comes to cars and modifications
    • I mean from V8 world there are gains to be made in intakes and such over stock items, but definitely only if you tune them. We're talking about I dunno, 10kw here and there on a 300KW v8, gains made by tuning in the 0.2 AFR that it changes so YES but also no you won't notice it other than the sound. Duct the air as mentioned 750,000 times and you will notice happier IAT's which definitely make a difference N/A. I mean my unsubstantiated guess is you'd go from 140kw with everything stock (after cams) to 145kw with everything and a tune :p
    • I decided to "spend baby spend", and "risk it for the biscuit" 2 Orders were made buying parts that I "don't really need but really really want" totalling $2.5k AUD 1: In stock items (intake plenum and throttle body) 2: The airbox thingie, with no real ETA for them getting more stock, so patience will be required
    • Any further updates on experiences with them? Anyone installed one with a getrag here as yet?
