Hi guys,
Having problems with my steering wheel shaking at 80kph and anything over 120kph. It's been happening ever since I got my new rims and tyres (235x45R17).
I took into a mate of mine, who used to work for Pedders, and now has his own business. He seemed to think it needing a wheel balance.
I've had new Whiteline adjustable radius rod bushes installed and a Whiteline rear control arm (upper) adjustable camber kit waiting to go in. It's got a front strut brace fitted & pineapples fitted, otherwise has stock suspension.
I've had several different workshops/tyre joints re-balance the rims and everytime they said they're fine. Also had an on-car balance done and it was all good. The only thing I couldn't do was a 4 wheel on-car balance.
I've had the Pedders suspension check and spring test done and it came up fine.
Will the rear camber kit fix the problem?
Anyone with some more suggestions would be much appreciated, as I don't want to keep hurting my baby.
:rofl:
Kyran
https://www.sau.com.au/forums/topic/71753-help-with-suspension/
what rims did you get??? maybe they are warped or buckled from the factory. also do you have new or second hand tyres?? maybe they have an egg in them.
a mates 180 does that too, its got a sloppy steering rack though.
get someone to wobble the steering wheel slightly while you look under there for any steering parts that have movement in them. all parts should be tight, and move together as one, if one moves a bit before moving the next component then it can cause dramas.
these are annyoing problems to develop and could be a number of components.
good luck champ
cheers
Linton
Similar problem here. Get a vibration over 100km/h after fitting new rims and tyres (18x8's with 225/40's). Wheels have been balanced three times and alignment done twice, all good. Have been doing a bit of bit research on various forums but I have not found any definite answers. Like NZM.031 says there are many components making up the suspension. The original, worn-out suspension rubbers are probably having trouble coping with the bigger, often heavier, wheel. You will have to get under there and look for excessive play. I found that my tension rod bushings are leaking and I will change these out within the next two weeks. Vibration at speed is also a sign of worn shocks. The standard shocks are good for about 60000km. Again, the worn shocks could be having trouble controlling bigger, heavier wheels. I found someone with a similar problem on a 300zx forum. His solution related the centre hole diameter of the wheel. Basically, the weight of the vehicle should rest on the centre hole of the rim, not on the studs. Most aftermarket rims are made to suit a variety of cars and have quite large centre holes. This means that the weight of the car rests on the studs. Apparently this can cause balance problems. Switch back to the original wheels and see if this solves the problem. I have sold the original wheels so I can't test this theory. Start by eliminating the easy stuff. I've been slowly replacing worn components with new items but the vibration is still there. Eventually I will end up with a fully adjustable race suspension set-up but with my luck the shaking will still be there.
Good luck.
Good luck.
It is ESSENTIAL that the wheel centres match the hubs, you can buy inserts (donuts) that fit into the rims if the centre hole is too big. Go to any decent tyre service and have them measure the hub and the wheel centre. It has been my experience that 99% of the time, running vibration is due to wheel balance or off centre wheel location on the hub. I have only found 1 or 2 cars that have had other causes, tailshaft out of balance or bent drive shaft/axle. And that is most unlikely on a Skyline, those components are very over engineered.
Braking vibration is usually due to warped disks, but obviously you only get that when you put your foot on the brake pedal.
:D
I had exactly the same problem. Got new tyres and asked for a 4 wheel alignemnt. Problem solved, no more shaking and its solid as a rock at high speeds. I think my rear wheels were a fair way out of alignment as the before and after data sheet showed alot of changed from before and after alignemnt. If that makes any sense.
  • 3 weeks later...
SydneyKid, cheers for the help mate. Had some rings made up for my car, the wheel is now centered on the hub but still no luck. The vibration is still there. My next step is to change the worn tension rod bushings and get the rims checked and balanced again.
  • 1 month later...
Hi guys,
Kyran
Hi there, sorry to drag up an old thread but I recently purchased new rims and tyres (235x45R17) - same size as yours - and I have exactly the same problem!
I have had balancing and alignments done as well as the plastic hub inserts installed but still have that annoying steering wheel vibration.
I found your thread via search as I would like to find out if you managed to resolve the issue. It is annoying the crap out of me. :)
I found your thread via search as I would like to find out if you managed to resolve the issue.  It is annoying the crap out of me. :(
I had the same problem on the Stagea, brand new tyres, standard rims and it had noticeable shake from 90 kph and quite bad at 100 kph. Took it back to have the tyres checked, all was OK. Still shake, shake, shake. I put up with it till I had to do a trip to Melbourne and back in 3 days. Enough was enough.
So I took it to a friend of mine who runs a huge tyre shop and we tried the wheels on 3 different balancers. All 3 showed different results, but 2 were pretty close, so we used them. Back onto the Stagea and no shake since.
My best suggestion is to take it back to whoever balanced them last time and ask for them to be checked. If you can find an on car balancer in your area maybe give it a try, they will pick up any fitment issues.
I have had the same problem with other cars, so it's not a Skyline problem. Hop onto any specialist car forum and you will always find some guys with vibration
problems.
:D
YAY! Happy news! I took the beast back to the tyre place and they performed an 'on-car' wheel balance (front wheels - left wheel was out so they 'rotated it on the hub') and VIOLA! - the vibration has gone.... :) HAPPY HAPPY JOY JOY!! Hope this helps all other peeps with 'bad' vibrations :P
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
