Hi Guys,
I have asked this question within other threads but have not got any replies, so I thought I would open it up to the wider community to see what response I get.
Does the R33 GTS-t have any camber adjustment from the factory? I have lowered the car and now have about 2degs of negative camber, causing the insides of my expensive tyres to wear faster, no good for my wallet.
The other question I have is whether when drag racing anyone bothers to have the camber wound back to neutral, to keep more rubber on the road, or am I worrying too much?
See'ya:burnout:
https://www.sau.com.au/forums/topic/7176-camber-adjustment-on-r33/
Duncan,
Yeah I've just had it done, there is very little in the way of camber adjustment, probably only 3/4 of a degree, so I may need a camber kit for the back if it's possible.
And yes you were right it was the toe in that was causing the wear on the rear tyres. Hopefully now I will get better traction for the drags, and reduce tyre wear. Hey wait.. aren't those two things mutually exclusive.
Thanks Duncan
See'ya:burnout:
dude,
You need adjustable top control arms (for d' camber) front, they go for around $500. Rear camber kit (bunch of different bushes and sleaves) bout $100.
While your at it you could do the adjustable radius rods for a bit of extra camber, for turn in and less nose dive under brakes.
Rev210,
Thanks for that, I knew somebody had to know about it. I take it I can get this sort of stuff through Whiteline? I was only thinking about doing the back, but if I want to race it then I probably should do it all?
Thanks for the help.
See'ya :burnout:
Originally posted by GTS-t VSPEC
Rev210,
See'ya :burnout:
They would be a good start.
If you can't get everthing from them let me know. I'm sure I'll remember who it was that does the different bits:cool:
Thanks, I think after this Wednesday I'll start off with the pineapples everyone is raving about and then start to improve the overall handling. In general I want the car for hard cornering and race tracks, but I'd like the occasionaly drag race. Is it possible to have both of these setups?
See'ya
:burnout:
Talking of suspension set-ups here's my compromise btw straight-line drag grip, all round driving & cost!
Rear camber - less than -0.5 using a Whiteline camber kit + the factory adjustment. From the factory you get -/+0.75 of adjustment. The Whiteline c/kits allow an additional -/+1.5 (via 2 kits) I only needed 1.
Front camber - -1.2
Whiteline rear subframe align/lock kit
Whiteline blade adjustable sway bars front & rear
Kings "low" springs (30mm lower than stock)
Standard shocks - I'd like to upgrade these but it's not on the list of priorities, in fact the shocks aren't too bad! Even the suspension workshop that I had do one of my alignments commented that my standard suspension components all appeared to be in good condition! Maybe those low kms are legit'!? Doubt it :D The standard shocks "should" also help with weight transfer upon launching.
All of the above changes have had some positive effect on my cars handling, mostly straight line grip!
BUT........ Without a doubt the biggest improvement to rear grip levels was fitting top quality tyres!
GTS-t VSPEC - In answer to your last question (in your first post) I don't so much as dial out the neg' camber but set my rear camber fairly neutral all the time. This way both rear grip & tyre life is maximised :P
Race track suspension? I haven’t got a clue in that dept’ ;)
Hicks,
She's more likely to vomit into your lap, and you having a 10sec car, I'd like to see that!
whatsisname,
Thanks for all the info. I currently have coilovers, which dropped my ride height, and at maximum factory adjustment the camber is still -1.3deg on the back, I'd prefer it to be neutral. I'll take what you said onboard, and hopefully when I have some more money I can start to get serious with the suspension and handling.
See'ya
:burnout:
GTS-t VSPEC,
-1.3 rear camber is about the same I had prior to the Whiteline kit (after lowering 30mm).
Lowering more than ~30mm without a camber kit ='s uneven tyre wear.
The Whiteline camber kits are cheap so it's easy fixed :(
Looking @ the level of engine modifications your car has/will have I'd be aiming for minimal r/camber! Unless you want plenty of :burnout: :D
Matt
whatsisname,
I think we dropped the height by 25mm or so, and are on the limit of the factory camber adjustment. The camber kit sounds the go, I just wanted the neutral camber to get more grip for drag racing.
I definately don't want :burnout: as I have expensive tyres normally.
See'ya:burnout:
Whatisname.
G'day Matt, how's things??
Hay can you do me a big favour and measure the distance between the middle of your wheel (front and rear) and the lip of the top of the guard.
I'm changing the suspension set up on mine soonish and need to know what the factory height is. I know that yours is 30mm lower than factory it'll give me a good idea.
Thanks
Jayson
G'day J,
Things are good mate :)
Yeah no prob's dude. I'll take some measurements & let you know shortly.
:D
Edit: I've had a quick look. Here's what I got.....
Front - ~340mm
Rear - ~332mm
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
