r33 boost
game33
 Share
true, well would that completely **** everything up u reakon, coz my mate done like 11 and it felt like when boost got up to high it cut out and like it was backfiring but it wasnt backfiring, if that makes n e sense, on a autop aswell, wats up with that??
thanks
12psi with stock ecu youll hit the "too much airflow" level and ecu will retard and cut timing
Only if your engine as a whole is making good power. Considering that I believe the RB25DET AFM is good for over 200rwkw than 99% people on stock turbo's will never have this problem.
Probably his fuel being retarded due to the ECU... 10psi is safe with the stock cooler also, anymore probably is pushing it abit!
hehe i hope his fuel isnt retarded.....BOOM!
I've been running 10-12 psi for a few years with no problems so far. Same mods as you.
A lot of people have said it's generally "safe" to go up to 14 or so without having the stock turbo cack itself. I've given it a go a few times but it feels like it's "choking" and is actually slower than at 12psi.
Maybe that's the stock intercooler doing its thing?? :D
Nah it wont blow up! It will make SHIT all power... lol
Ull be going huh why am i so slow now hehe
what i mean is, it wont be the fuel rate slowing down...rather the ecu will chuck in more fuel to compensate for any pinging (with increasing boost) aswell as retarding the timing....thats why the rate of acceleration decreases
 Share
    • Hi all,   I have been a member here for years and am back to owning an R35.  It's my car and thought members of the community might enjoy sharing my journey.  I am definitely here to join the conversation.  If sharing this content isn't appropriate or it belongs somewhere else, I am happy to have it deleted or moved...
    • Data looks rock solid? I'm assuming you jabbed the throttle twice OR once? the TPS voltage moves up and down twice, however you've mentioned you did it once.
    • Having not watched the videos, I'm unsure, but this may be better suited to the importing thread?
    • Update on this situation: (Forgot to put in my previous post that I bought another brand new pressure gauge and fuel shows the same 50psi) I've deleted all the aftermarket immobilizers and turbo timer shyt and placed all factory wiring back to normal. The problem is still the same and nothing changed, but atleast it's a bit more tidier under the steering wheel. I've also siphoned out all the old fuel and then poured new batch of BP98 fuel (about 15L) into the tank. Nothing changed. Still the same idle. I also changed out the MAP vac line with a new one and, still the same.  So 2 days ago, I thought fk it. I'll just change out the fuel rail and injectors with another set that I know worked well in my brother's R34 a while back. That other fuel rail has the exact same Xspurt 640cc as what I have right now. So I changed it out to that other fuel rail and injectors (new O-rings) and injector harness. Put everything back together, started the engine, 464906286_1624569924763105_5179888796065901094_n.mp4   and yeah... still the same 50psi and idle problem. 🫠 I can also hear each of injector's solenoids running when I put a screw driver to it and have the other end to my ear. I might get a noid light just to confirm pulsasion but yeah, very strange that both fuel rails and injectors put out 50psi.  31-10-2024.csv I've attached it here. I started recording, then started the engine and let it idle with no throttle, then at the end I applied a little throttle and then stopped recording.    So, now idk. I'm going to see if swapping out the brand new R35 coils to my old splits fires will change anything. 🤷‍♂️
    • Hey mate, nice work on the car. Just a quick note, people generally don't like it when you use the forums to dump and run to advertise your YouTube content. If you're gonna stick around and join in the conversation then great, but if not this might not be the best place for you.
