Just don't drain it first or you'll have a heap of fun trying to get fluid back into the master cylinder.
Just fill the reservoir up and pump the fluid through, topping up the reservoir as you go. Do it the same way as you would your brakes. Stop when the fluid coming out of the slave bleed is clean and bubble free.
This may sound like a stupid question.. but where the hell is the clutch reservoir on a RB25DET GTST. My clutch is slipping like a biatch, and im hoping it 'may' be fluid as im broke
I doubt its clutch fluid.. havin low or air in the fluid makes your pedal go to the floor without disengaging the plates it wouldnt affect the operation of the clutch when the peddal is not depressed. sorry sounds like new clutch time
Yeh... i just got some clutch fluid today... but found out my reservoir was actually OVER filled, took some out but still the same. I think i need to go for a new clutch too
i would also recommend before getting a new clutch..
check your master and slave cylinders as sometimes the seals in these things go and they dont hold the clutch fluifd in as its leaking out through the sides. UIsyour master clutch cylinder leaking?... if so u can get a new one for 70 bux or a slave one for 60bux.
it wouldnt be leaking cos the reservoir was full (overfull actually) That was my first thought, but if it were leaking, my guess is that it would be bone dry. Also ive tried taking some fluid out but clutch is the same.
Im booked into getting a "9 Puck cushion button extra heavy duty clutch" ... or whatever the hell that is. I was told that would be good, for $850 installed. Plus possibly $50 for machining of the flywheel if needed
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
